Home > Technical (L322) > Gearbox on it's way out?
Lets hope so Thumbs Up
Post #71209 4th Jul 2011 10:58pm
SteveMFr
Site Sponsor
Mikey, just to calm you a little: generally when the converter goes on the 5l40E it's accompanied by vibrations as it breaks up. While it's not a guarantee, I think you're suffering from the 'awareness effect'. Similar to the 'clean car goes faster effect' but usually associated with problems... Razz
Warm day, window open - I'm going to say viscous coupling as well.
You'll see when the flush is done. A converter breaking up leaves lots of metal in the pan (make sure they pull the pan, btw, I've heard of flushes being sold as a better way to change the fluid - w/no need to drop the pan...)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #71214 5th Jul 2011 6:22am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Mines done 50,000 miles so not likely that the gearbox has had it just yet but I noticed on a hot day the engine sounds a bit like a 747 on take off. I put it down to the fan being on more. Really does sound like a huge amount of air being forced out.
Same used to happen with my P38 as well so I suspect it is the fan you are hearing and seems totally normal. Ash
2016 SDV8 AB
Post #71219 5th Jul 2011 8:34am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I have been experiencing the same sort of roaring engine. The conditions are quite specific; when the outside air temp is high and accelrating from being stationary or slow moving - oh and the window/roof open. It sounds [good description] like a 747, but then after a short while it returns back to normal. The engine temp guage always remains steady.
Post #71222 5th Jul 2011 9:15am
Johnte
Good description, that's just what mine's like - I was starting to get worried, but looking now like it may be normal Thumbs Up
Post #71224 5th Jul 2011 9:41am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
OK, latest news, had the box diagnosed today at an auto specialist. Seems to be working fine, no obvious problems. The guy showed me a 2 foot long printout (which I kept), listing a few past faults etc. He did say there was a possible intermittent fault with the transfer case actuator as a sensor was showing "noise" which can send false signals to the computer and cause odd gear effects from time to time Rolling Eyes I must admit I got a bit lost listening to him explaining the various tests and faults etc.
He didn't try to sell me any work and just said to keep an eye on things.
Anyway, the car was tested for about 30-45 minutes and I didn't get charged or anything. Great service I thought.
As I was planning to do it anyway, I booked it in next week for a ATF and filter change. They have tech-tronix equipment that supposedly gets 99% of the fluid out. The cost is in the region of £170. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #71442 6th Jul 2011 6:50pm
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
That's great news Mikey and from the sound of things a really good service.
Care to name them? - I guess if you posted it in Dealership Feedback it could be useful?
Cheers
Steve
Post #71501 7th Jul 2011 8:58am
Mikeyjd
The place I went to is:
Chester Automatic Transmission Centre. (actually in North Wales - just across the border). they specialise in auto trans and air conditioning. They really seem to know their stuff. Will let you know how the car runs after the service. If I am allowed to post their website, here it is.
Www.transcentre.co.uk No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #71504 7th Jul 2011 9:21am
Vogue
do you know if they are using the recommended oil, or just generic ATF?
Post #71759 8th Jul 2011 10:23pm
Mikeyjd
Good point, I will check out with them. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #71768 8th Jul 2011 11:18pm
