Home > Maintenance & Mods (L322) > L322 5.0 SC Vibration under light acceleration
Page 2 of 4 <1234>
Gsxr1250dave
It's David's great post iv been using for guidance iv just run down the motorway and back and the revs are still bouncing up and down ever so slightly as before and obviously the shudder.
The big debate is do I reset the adaptations or not, David did this on his 1st 5.0 but the gearbox soon gave up and Phil says not to as well.
I think this is best practise so il be ordering a full set of solenoids tomorrow. Thumbs Up
Phils post on the subject about resetting adaptations
Post #712346 20th Feb 2025 10:05pm
dhallworth
The one I reset the adaptions on was a 4.2.
I misdiagnosed that as being a faulty gearbox as after swapping it I had the same fault. It was the transfer box on mine that was causing the problem. A new transfer box from Duckworth's sorted my problem out and it was perfect afterwards.
If you've got a problem I'd not reset them after an oil change. I did reset mine on this 5.0 after I'd changed the solenoids though and it's been perfect since. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #712354 20th Feb 2025 11:15pm
Gsxr1250dave
Thanks David for clearing that up I'm going to order a full set of solenoids today then report back. Hopefully from the place you got yours from.
Post #712366 21st Feb 2025 8:48am
dhallworth
They’re definitely worth trying as its a much easier fix then doing the torque converter.
I did the dampers in the valve body on mine whilst it was apart.
Got everything crossed that yours is a simple fix too.
Post #712377 21st Feb 2025 10:30am
AlexTVR
Indy reckons I need a new gearbox, won’t do anything with a refurb unit and mentioned £8k+ for a new box 😂. Looking at cars history another Indy did a flush under 15k miles ago, but oil looked fairly dark with some tiny shiny specs😏
Drove OK on way home 🤦‍♂️ 2010 Supercharged
Post #712864 26th Feb 2025 5:04pm
Gsxr1250dave
Maybe do the same as me I'm still waiting on sussex autos to get back to me on price and stock of a solenoid kit there web site lists it but they just don't seem to answer emails or what's app enquiries . I mean how hard can it be to reply to customers Neutral
I hoping mines just a solenoid as David proved with his after swopping 1 out lent by Phil.
If I don't get a reply back by tomorrow il just order direct off their site
X1 solenoid kit
X7 litres zf6 life guard fluid
Swop them all out do an adaptation reset and see what happens.
Post #712866 26th Feb 2025 5:31pm
AlexTVR
Also slightly confused by model numbers, a build sheet I have for my RR says “ 6 Speed Auto ZF 6HP26 Steptronic (078BO)” but on here I’m seeing the 5.0SC has 6HP28 ? 2010 Supercharged
Post #712868 26th Feb 2025 5:47pm
Gsxr1250dave
Yep zf6hp28 fitted in the 5.0 sc
Post #712871 26th Feb 2025 6:30pm
dhallworth
I only ever dealt with Sussex Auto's by phone and found them very good to deal with. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #712905 27th Feb 2025 12:07am
Gsxr1250dave
I'm calling them in the morning David iv just not had a reply to my emails and what's app message. Thumbs Up
Post #712906 27th Feb 2025 12:10am
AlexTVR
?si=b6J99q4Aw4zokF73
?si=FutCJx3uKpt_lIo9
Couple of vids that could be useful for solenoid work (the 1st one gives me hope when the Aussie mentions mileage and swarf 2010 Supercharged
Post #712960 27th Feb 2025 7:26pm
Gsxr1250dave
Think iv seen pretty much everyone of those vids on the tube good how to guides.
Spoke to sussex autos they have all the bits I need in stock just waiting to sort out final order.
Post #712971 27th Feb 2025 9:27pm
Gsxr1250dave
Box of goodies arrived yesterday weather dependant I'm planning on Friday to swop out the solenoids.
Post #713285 4th Mar 2025 11:29am
fullfatfearns
Well… just had the car back from the dealer. Pic of the gearbox service attached. Dealer experienced the original issue, and drove it around 60 miles on his way back to me and states that it’s entirely gone after a bit of driving. Bloke that worked on it said oil came out looking very burned.
Will drive it round for a bit and fingers crossed it’s sorted. Will call it a lucky break if a fluid change and adaptations has sorted it out! Will update here in a few weeks and a few hundred miles.
Best of luck to the rest of you, too!
Post #713306 4th Mar 2025 6:11pm
fullfatfearns
Post #713307 4th Mar 2025 6:12pm
Page 2 of 4 <1234>
