![]() | Home > Technical (L405) > ENGINE FAILURE 4.4 SDV8 |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
How often do you change the oil? 2018 SE SDV8 4.4 Byron Blue |
JIMMY1907 Member Since: 24 Feb 2025 Location: PAISLEY Posts: 5 ![]() ![]() ![]() |
The oil was changed every annual service as we only do around 6k per year .In hindsight i wish i had it changed twice a year but there was absolutely no warning`s or any signs of it going to happen |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
thats low mileage to have the engine go kaput....
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
![]() A taxi might have been a whole lot cheaper, if you’d turned off the engine there & then. After 8 miles, a lot more damage is very likely. Sorry to hear about your woes, best of luck. V6 Vogue - “Less is More” - less to go wrong! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
After seeing the damage to my son's TDV6, once a noise was heard the crankshaft would likely to have been ruined. If it didn't seize then at least the conrods and pistons might be OK. |
