Home > Technical (L405) > ENGINE FAILURE 4.4 SDV8
JIMMY1907
United Kingdom 2017 Range Rover Autobiography SDV8 Montalcino Red
Looking for some advice/help i travelled approx 8 miles home since hearing the engine making a horrible noise probably the bearing turned on the crankshaft, since i have took the filter out its showing the glittery swarth. Incidentally my car has just turned fifty thousand .Just wondering what the chances of the turbos or heads been damaged
Post #713235 3rd Mar 2025 12:40pm
Kot
How often do you change the oil? 2018 SE SDV8 4.4 Byron Blue
Post #713237 3rd Mar 2025 12:48pm
JIMMY1907
The oil was changed every annual service as we only do around 6k per year .In hindsight i wish i had it changed twice a year but there was absolutely no warning`s or any signs of it going to happen
Post #713242 3rd Mar 2025 1:35pm
thats low mileage to have the engine go kaput....
sorry to hear this and hope it doesnt cost to much to sort out.. ... - .- -.
Post #713243 3rd Mar 2025 3:19pm
Gremlin500
Re: ENGINE FAILURE 4.4 SDV8
Shocked
A taxi might have been a whole lot cheaper, if you’d turned off the engine there & then. After 8 miles, a lot more damage is very likely.
Sorry to hear about your woes, best of luck. V6 Vogue - “Less is More” - less to go wrong!
Post #713245 3rd Mar 2025 4:42pm
GraemeS
Australia
After seeing the damage to my son's TDV6, once a noise was heard the crankshaft would likely to have been ruined. If it didn't seize then at least the conrods and pistons might be OK.
Post #713257 3rd Mar 2025 8:25pm
