![]() | Home > Technical (L322) > Stuck 3rd Gear |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1021 ![]() ![]() |
The transmission cooler is an oil-to-water type that receives its coolant flow from the bottom eight rows of the main radiator (controlled by a thermostat). When the bottom of the radiator (or the water side of the oil cooler) gets blocked the cooler has nothing to cool the transmission fluid with, so the fluid overheats.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
We had the exact same thing happen on our previous 4.4V8 Petrol L322. I had some information somewhere about it.
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 117 ![]() ![]() ![]() |
I wonder why it’s not triggering a fault code Des
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
Hi Everyone,
So I changed the main radiator this morning, got the engine up to full temperature to make sure it was bled ok, and then took it out for a 20 minute drive.
That all sounds right. The transmission fluid temperature should be around the same as the engine coolant temperature (maybe a few degrees lower). The engine thermostat is nominally set to open at 105ºC. Edit - incorrect information: but the coolant temperature can exceed this at part loads as the electric thermostat heater is employed, to improve fuel economy & emissions.
Thanks Phil, that makes sense except that I replaced the electronic thermostat last year after it failed with a 88c thermostat, however even with this lower thermostat the engine temp still reads 101c, and transmission 106. |
I believe that the measured coolant temperature (i.e. temperature at the sensor) is higher than the thermostat opening temperature because the coolant has circulated through the engine by the time it reaches the sensor, but whether that would explain the 13ºC difference I’m not sure.
Actually, thinking about it, the difference between the maximum coolant temperature I measured (117ºC) and the standard thermostat opening temperature (105ºC) is also around 13ºC, so maybe that is the normal difference between the two? The electric thermostat heater is activated by the engine management system when the engine is under higher loads to force the thermostat to open at a lower temperature.
Thanks again Phil.
Back in the day (15+ years ago), the diagnostic kit to have for the L322 was the Blackbox Solutions Faultmate MSV-2 Extreme, which cost around £925 (& that's when £925 was a lot of money ![]()
![]() Phil |
Wow that's an investment, very nice |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8728 ![]() ![]() ![]() |
AFAIR there are three coolant sensors and you have to know which one your reading is from...
Thanks Pete.
