![]() | Home > Technical (L322) > Lights Gone Mad Failed LCM |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 63 ![]() ![]() ![]() |
So it seems that failure of the LCM (Lighting Control Module) on the L322 and BMW's of the same era (which have a similar module) is something that can just happen. There's a guy in Harrogate that you can find on Ebay who specialises in repairing them. His company name is Autoelectron. He has a 100% positive feedback score. From what I've read one of the chips/processors on the board goes bad and has to be replaced.
So I sent my LCM off for repair.
So there actually weren't too many second hand ones on Ebay that would fit my car, different units depending on the year. Second hand cost by the time its shipped to Ireland was working out at 450. New genuine form LandRover was 650 Euro, so I have ordered a new one and have arranged with a local indie guy to programme it to the car.
tracker Member Since: 22 May 2024 Location: Paphos Posts: 30 ![]() ![]() ![]() |
Hi Chris, that's quite some extra work when replacing the rear view camera... Do you have an idea why the PCM broke? Did you disconnect the battery before disconnecting the camera etc.? Do you know how the PCM is programmed? |
Hi tracker,
So after unsuccessfully trying to get the new genuine LCM programmed by a local indie I have fitted a used LCM with the exact part number and all is good, although I do have the tamper dot next to the mileage reading... All the best
