![]() | Home > Technical (L322) > Ignition lock |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8821 ![]() ![]() ![]() |
Pretty sure that is an immobiliser fault, IIRC it was fuse 18 that covers this, a lot put a switch inline with the fuse so you just toggle it to get the key to turn, it eventually leads to component failure and you need a new lock...
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Hi,
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 834 ![]() ![]() ![]() |
dont know about the 2007, mine is a 2005
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Steering lock mechanism on its way out, can fail in the unlock or lock position, you can get away with drilling a hole in the side of the housing in a particular place and lubricating but it's risky and doesn't last, really need an upper steering column to sort it out, expensive, or the bypass that's available about 60 quid iirc.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
I've been having the same issue on my car for a long time.
The emulator is plug and play so you just unplug the lock ECU and plug the emulator instead.
Great!!
You're most welcome, enjoy your FF |
