![]() | Home > General (L405) > Security Update - 2016 MY onwards. |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Not sure what model you have but it's possible to disable keyless to prevent relay theft so it might just switched off and most would recommend leaving it off for an additional layer of protection. 2021 P400 Silicon Silver AB
Les XRN Member Since: 13 Feb 2025 Location: Cheshire Posts: 9 ![]() ![]() |
It's an L494 Sport. It definitely doesn't have keyless, no touch pads on the door handles. The fob is the only way to unlock/lock. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1169 ![]() ![]() ![]() |
What year and model is your Sport , very unusual not to have KE. overfinch modified |
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 208 ![]() ![]() |
Does anyone have the chassis number from which the sleeping batteries are needed or year ??
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 182 ![]() ![]() ![]() |
The facelift in 2018 is the point where UWB keys were introduced. The tell tale is whether your key is the new shape with the LR badge on the back or the old shape with the chrome Range Rover strip down the side. |
Thanks Alex , I should be ok then.
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
That's probably longer than the batteries will last! ![]() MY19 SDV8 Autobiography - Sold |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1796 ![]() ![]() ![]() |
Our batteries finally arrived yesterday after 7 months! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8761 ![]() ![]() ![]() |
Mine arrived this week as well.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1476 ![]() ![]() |
My batteries arrived yesterday too, although now I have a 2021 I don't need them anymore |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8731 ![]() ![]() ![]() |
Got nothing but scathing on Amazon... https://www.amazon.co.uk/Sleeping-Battery-...RPKZ3?th=1 Anyone got a link to the devise that does the same but uses normal batteries...?? Edit:- Found it... https://www.powerfuluk.com/products/keyfob...des%20a%20'battery,signal%20that%20the%20thieves%20intercept. Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
I knew there was a reason why I didn’t throw my cr2032 batts in the bin…. |
Hi. It's a 2015, originally delivered new to Switzerland, not sure if that's relevant re; the lack of keyless though. |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 247 ![]() ![]() ![]() |
So it's 6th May 2025, and my sleeping battery just died in my key fob, so that's about 4 months - I installed 13th Feb 2025. Not brilliant. two batteries is £85 so that's about £10 a month (2 batteries last 8 months) to improve security. Andrew -- On my third Full Fat RR |
