Home > Maintenance & Mods (L322) > Window trim surrounds
Speedbird209
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
I'm thinking this may be a bit of Hail Mary but I've had no joy on the intergoogle and hope this makes sense.
Some of the black window trims on our barge are bubbling. They "appear" to be made of metal with a rubbery / plastic coating.
Does anyone know the part numbers, or where I've a half decent chance of buying replacements. Slightly frustrating that some have bubbled yet the upper tailgate is like the day it was made.
Many thanks
Post #713300 4th Mar 2025 4:35pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Here's a link to the thread about this
https://www.fullfatrr.com/forum/topic64731.html
and another
https://www.fullfatrr.com/forum/topic65080.html
Post #713308 4th Mar 2025 6:15pm
Speedbird209
Many thanks for the guidance RHO which has taken me to potential supplier.
Down to me for clumsy wording and mentioning upper tailgate.
It’s the some of the window strips on the doors so I’ve messaged JRS to see if they have them.
Once again, many thanks !
Post #713315 4th Mar 2025 7:39pm
tracker
Cyprus 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
It seems these are available from jaguarlandroverclassic.com: https://parts.jaguarlandroverclassic.com/p...2MTY0MTA./
Post #713395 5th Mar 2025 9:31pm
Speedbird209
Brilliant ! Those are the ones: many thanks, just hope they have some.
Post #713398 5th Mar 2025 10:00pm
Jimnic007
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Baltic Blue
I am following this thread with interest, as I have a couple of the b or c pillar finishers that have bubbled. Do you know how easy they are to remove and replace?
Thanks,
James
Post #713483 7th Mar 2025 12:45pm
Speedbird209
TBH, I’ve absolutely idea at the moment so have a two pronged strategy.
1. Am going to NEC resto show so usually Rangey stand or two and they’re v helpful.
2. Plan B, dig out trim removal kit, try find some videos online and if not take a logical approach then probably cry myself to sleep if get it wrong: positive though will only be on one trim🤪.
Post #713591 8th Mar 2025 7:28pm
Jimnic007
Brilliant, can't wait to see the results. Please keep us posted! Laughing
Post #713683 10th Mar 2025 9:52am
Jimnic007
Any update on this, did you manage to obtain the replacement trims and have you been able to fit them?
Thanks
Post #714593 21st Mar 2025 11:58pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
I have just taken delivery of a replacement driver's door outer lower seal and yet to fit it.
Basically RAVE requires internal door panel plus other parts to be removed as part of the process.
Unless I missed that meeting when it was decided to part dismantle the driver's door which will result in needing to re-glue retainer clips and fixings all that is required is to remove the old surround and fit the new one. You don't even need to open the driver's door to replace the part. The new part will fit under the B post trim as it has a cutaway section. What I have noticed is that the new trim has a steel section internally to give it strength and the end at the front where it meets the mirror is nice bright cut shiny steel! hence why mine has rusted badly at this point. This I will deal with before fitting to seal it but as mentioned I have yet to fit it as I might be missing something about why I need to remove lots of stuff according to RAVE. Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #714639 22nd Mar 2025 11:54pm
Speedbird209
J 007 update: short answer is no, no progress yet primarily because I refused to give in on the Phillips screw that holds the N/S reversing light lens.
When I went to replace the bulb the part part of the lens moulding where the screw goes through was brittle and disintegrated leaving the screw in situ. The screw sits in a grommet / lug which felt like plastic. It's also within the cavity of 2 skins. After losing a lot of skin on knuckles etc the only way to get the *&&&^^^ out was to drill the screw top off. The grommety thing is metal and was a complete pain hence me getting side tracked; anyway, problem now sorted.
Was at the NEC resto on Friday but completely forgot in the excitement of everything to actually hunt down a knowledgeable stand so it's still on the to do list but will post when tackled.
Post #714679 23rd Mar 2025 6:07pm
