![]() | Home > Technical (L322) > L322 4.4 TDV8 Radiator Top Hose Connector Leak |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 292 ![]() ![]() |
Yes, that is the thermostat housing. It's fiddly but there is just enough room to pull back the top hose and the other without removing the fan. You can buy the O rings for the hoses from eBay for not very much. Whether your leak is from the housing itself is not clear. 2012 Vogue TDV8 in Aintree green over sand |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 36 ![]() ![]() |
Thanks for this. Will let you know how I go. |
Is anyone able to identify the size of the O'Rings required to be replaced for both of these hoses? Do they need to be Viton? |
