![]() | Home > Technical (L322) > L322 4.4 TDV8 Radiator Top Hose Connector Leak |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 313 ![]() ![]() |
Yes, that is the thermostat housing. It's fiddly but there is just enough room to pull back the top hose and the other without removing the fan. You can buy the O rings for the hoses from eBay for not very much. Whether your leak is from the housing itself is not clear. 2012 Vogue TDV8 in Aintree green over sand |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 41 ![]() ![]() |
Thanks for this. Will let you know how I go. |
Is anyone able to identify the size of the O'Rings required to be replaced for both of these hoses? Do they need to be Viton? |
Have been putting this one off and finally have time to complete.
If you continue to read the thread that you linked you will see that it is internal. 2012 Vogue TDV8 in Aintree green over sand |
