![]() | Home > Technical (L322) > Stuck 3rd Gear |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Yep, that's the part, IIRC you can't dismantle it without wrecking it, it's plastic moulded around the small stat... If you remove it I guess you could try the whole thing but that means doing the job twice and trying to test it's flow while it's a lot hotter than hand hot...!! Pete
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Some info. here : https://www.landyzone.co.uk/land-rover/200...ge.231195/
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
That's a great right-up and I do love a lot of pictures |
The manifold also heats up the fluid when it's cold so although you would get a difference in temp output it might be hard to decide which is which and whether it should be hot or cold...!! Pete
Thanks Pete, I guess I'll buy the thermostat housing and then get a new oil cooler if that still doesn't drop the temp sufficiently. |
Just to update the thread, as one of my pet peeves is when people don't let everyone know the outcome.
