Home > Maintenance & Mods (L322) > M62 5hp24 Gearbox issues
jbridges522
Hi, Long time lurker here for maintenance guides, diagnosis help etc so thanks for that, esp @rrphil .
But Im currently a bit stumped, my M62 2004 L322 is unfortunately refusing to stop showing symptoms of a bad torque converter. The usual cattle grid style rumble, dropping revs at times etc.
I have done the usual, oil and genuine filter, instant shudder fix etc.
So my question is, what really are my options going forward? Im a keen DIY mechanic and would struggle to pay someone I'm guessing 2-3k for a recon box and tc, but is it worth trying to remove the tc and refit a reconditioned one leaving the gearbox alone? Try and rebuild the gearbox myself, do places offer diagnosis if I was to remove it and take it to them?
Basically I'm looking for advice please as im a bit stuck without anyone with knowledge to advise me.
I have a breaker with the same gearbox but im looking to get the rr in question to 200k, sitting just below 150k currently so not really wanting to just stick the other one in and kick the can down the road, but could possibly work in my favour having a spare box.
Thanks!
Post #713726 10th Mar 2025 8:37pm
RRPhil
Quote:
....is it worth trying to remove the tc and refit a reconditioned one leaving the gearbox alone?
Yes, definitely. That’s exactly what I did with my L322.
If you’re able to drop and re-install the transmission yourself, a remanufactured converter should set you back around £250-£300, but I’d recommend that you use a specialist supplier such as Sussex Autos or JPAT. Often you send your converter to them and they remanufacture your actual unit and return it to you within a couple of days.
Phil
Post #713746 11th Mar 2025 12:42am
jbridges522
Thanks Phil, I will scour the internet for removal guides. I believe it can be quite tricky to get the tc back in correctly, did you have any issue getting urs back in?
As for who to use I'm a bit more limited being based in ni but will see what my options are.
Interms of solenoids etc is there any guide to testing them to see if they would be causing the issue?
Thanks again, very much appreciated.
Post #713778 11th Mar 2025 11:49am
RRPhil
Quote:
I believe it can be quite tricky to get the tc back in correctly...
It’s critical that the slots in the torque converter impeller drive tube engage with the drive dogs on the oil pump gear
When you offer up the torque converter, and rotate it to line up the oil pump, you’ll hear a clunk and the torque converter will drop in. This is the tapered snout of the drive tube engaging in the cast iron seal and is not the oil pump drive engaging. You then need to keep turning the converter until it clunks and drops in for a second time and engages to the correct depth. Not difficult – just needs a bit of patience. To check that the pump drive is fully engaged you need to check the dimension from the face of the bellhousing to the four welded pads on the converter which take the flexplate bolts. This should be 25mm.
You could try swapping EDS 4 (which controls the torque converter lock-up clutch) with one of the other black-cap solenoids, just to eliminate it, but I doubt that’s the issue. You can check the resistance of the solenoid windings with a multimeter, but this only tells you if the winding is okay, and doesn’t tell you if the solenoid is functioning correctly hydraulically.
Phil
Post #713891 12th Mar 2025 1:14pm
jbridges522
Cheers Phil, sorry didn’t see your reply.
Another symptom I noticed yesterday was being able to push the car into neutral without putting my foot on the break (did it accidentally) if that points to anything else.
Thanks again for the guidance on the TC.
Post #714777 24th Mar 2025 4:07pm
jbridges522
To update this I haven’t proceeded with the tc swap yet but it is getting worse, tempted to try one last oil change and tube of additive but think I will have to bite the bullet.
Post #718052 16th May 2025 1:34pm
