Home > Technical (L322) > New 2012 Westminster owner, 3 months in after some advice
Page 3 of 3 <123
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I had the same quadry so what I did was cut off the compressed pipe clamp to the right angled plastic connector and replaced it with a jubilee clip, in that way it meant I could do the O ring removal and fitting to the plastic housing on the bench.
Then connected the right angled connector to the oil cooler got that on securely then fitted the pipe and tightened the jubilee clip.
Much easier that trying to fit the O ring correctly at full stretch with the risk of dropping it and also that spring clip on the connector itself.
Also there is very little space to manouver that connector with the pipe attached.
Cheers.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #712635 23rd Feb 2025 8:57pm
diabloam
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
sounds like a decent approach, you go with wee Dremel style cutting disc or careful hacksawing diagonally?
Post #712659 23rd Feb 2025 11:14pm
AndyRoo
If I remember the standard clamp is one that has some latching tabs that latch it in a loop and a special tool tightens it, so then you can just find the join and prize it apart using a small flatblade screwdriver.
Post #712661 24th Feb 2025 12:19am
diabloam
Well after my replacement parts came, replacement for cooler and pipe I broke went missing in post, new ones sent out and went to refit tonight. Getting on fine, cooler on and built up cleaned throttle body and inlet plenum and was about to fit whole inlet when noticed these two pipes coming from vacuum pump are not connected to anything, covered in oil from air inlet hose. I do not remember disconnecting them
They seem to go down under front of passenger cylinder bank to I think some kind of vacuum solonoid. I look down and can see where it looks like they go, but only one looks like it connects as other is solid end to solid end rather than soft pipe. Anyway whilst fumbling about a piece comes out, here it is cleaned up
so I am not sure quite how it goes back on, there is an outlet on solonoid that looks like it soft pipe
so guess it goes there and t- piece goes into furthest in pipe and that would seem to be the hard hard pipe connection I originally could see, is there a small section soft pipe missing from t piece to the hard pipe. And then other hardpipe goes into soft pipe. I know that is hard to follow, anybody know how this all goes together? They are not great connections and wouldnt surprise me if they were off to begin with but equally when I was replacing that wee water pipe I snapped I may have pulled them off. other photos below
frustrating as its now been off road in garage for a fortnight with bits going missing, thought I would get it back together tonight Crying or Very sad
As always any help greatly appreciated
Post #713926 13th Mar 2025 12:40am
kevinp
If you go on ebay and search for the engine, you will see quite a few engines for sale that have good front end photo's that might point you in the right direction.
Post #713929 13th Mar 2025 1:10am
diabloam
Managed to suss vacuum pipes and got everything else back together, topped up coolant, dash said oil was ok (double click cruise cancel button as was cold) and off I went out for a spin, all seems well, purring and no obvious leaks, happy days.
Thought would check levels and leaks under bonnet and lo and behold cable pull to release bonnet is loose and bonnet wont open, argh!!
popped the floor trim off and then trim round cable release lever and can see its snapped just there. Set vice grips on and bonnet opens, so guess I am looking for a release cable, Quick google and I see this one listed FPF500040 from Advanced Factor where I have been getting parts https://www.advancedfactors.co.uk/fpf50004...rhd-models
However googling part number it seems this part is for up to 2009 and my RR is 2012. Is it this one I need LR011474? Annoying if so as it £12 against almost £40. Anyway, I will do search on site to see but anybody know off top of there head? and also, how much of a pia is it to do. Frustrating one, lol, gotta love them, even when your RR likes the comfort of the garage too much. Anyway I took engine under covers off so can clean them whilst waiting as they are covered in oil and coolant. Happy days, lol
Post #714375 18th Mar 2025 10:32pm
toby1
There is a parts catalogue (and workshop manual) in the wiki and that says FSE000030 front, FSE000041 centre and LR011706 to the handle.
https://www.lrcat.com/#!/12719/110957/111012/8790 2012 Vogue TDV8 in Aintree green over sand
Post #714385 19th Mar 2025 9:45am
diabloam
Still not completely clear from that. Is it LR11474 and LR011706, one is for RHD and other is LHD or something, anybody had this and bought one of these, which is which?
Thanks
Post #714390 19th Mar 2025 10:52am
diabloam
Still not clear after doing search, anybody? thanks
Post #714447 19th Mar 2025 8:15pm
diabloam
Many thanks, got her back together and running last week, no obvious leaks, got a cable to replace bonnet one but aint stuck that on yet, many many thanks for all the help. Will be getting onto knock (prop?) and bonnet cable when get chance later this week, great to be back going
Post #715220 30th Mar 2025 9:26pm
diabloam
still not done bonnet release cable but being driving couple weeks now, not seeing any drips underneath and oil and coolant seem to be staying put level wise.
Still occasionally getting a little wiff of hot oil, do they take a wee while to clear and burn off any residue? Definitely way less than before so I am hoping so. I also did the three big o-ring mod to the throttle body intake so hoping that sorts the mess that had built up there so am hoping all in all looking good.
I have big tub oil and the draper extractor and I also bought a new filter. However given there was a new oil filter in the cooler I fitted, would you guys just leave filter this time and just refresh oil and save filter for another change in few thoasand miles when I do it next or am I just being too much of a tight ass, lol?
The light thumping when pulling away, more pronounced when doing a right turn seem to be marginally worse, am hoping it is prop but aint had chance to look closely. Hoping some garage time later in week. Doing a search on this suggest other things, tyre, tyre pressures, diffs, transfer box etc, what thoughts. sure I can fell it under my elbow when resting it on centre console which was what made me think prop? Thanks again for any pointers as always
Post #716599 22nd Apr 2025 8:20pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Diabloam
I was recently also getting the clonk clonk when turning right
Glenrands diagnosed a worn / noisy half shaft from the front differential to the right front wheel
Half shaft changed and noise has gone
Post #716656 23rd Apr 2025 5:41pm
diabloam
This doesn't feel or sound like it is from the front though, also seem to be able to feel it through elbow on console etc, but sounds move about, did you feel it like that?
Post #716712 24th Apr 2025 11:16am
Rambles
Where you say:
“It only really seems to do when turning right whilst pulling away at a junction and otherwise silent and clonk free even when giving it some beans.“
That’s exactly the same when i experienced the clonk clonk.
Also when going round really tight roundabouts
The sound didn’t move about….but could be reliably recreated on every drive.
Re centre prop shaft, i am on my third.
The first lasted 110k miles
The second barely 10k miles
Hoping the 3rd lasts like the first
There were no noise symptoms from the centre prop shaft.
Q: why should turning right when pulling away generate a clonking from the prop shaft but hard acceleration in a straight line has no effect?
Post #716723 24th Apr 2025 3:07pm
diabloam
updates,2012 bonnet release, DPF values amd EGT code
Hi all
Got my bonnet release cable done, bit of a faff, these later ones do not have a rubber grommet that seems to drive people crazy so perhaps the late L322 are easier. pain to fish up in engine bay at bulk head, I pulled out that black box in pics (not sure what it is, slots in with only 2 nut holding it) and also the big wiring rubber block holder, makes it much easier. Cable itself connect to front section as in other posts. If you look at pics you can see different setup where cable goes through the bulk head. Advanced factors did not have this later cable so got it off maltings, £40 odd squid so think pricier than earlier cables, part number was LRO11474LR. So got that all back together.
Also on advice from on here, did first oil change, bought Smith & Allan Momentum C1 F 5W-30 and the recommended Draper vacuum drainer, works great, left oil filter as it was new with cooler.
I have also bought a GAP G3. After changing oil I reset service and check calculated soot level, think it was 17g. Went for a good thrash and all seems well. Check soot yesterday and left GAP in and monitored, started at 6g or so, so I am defo regening ok, got the common EGT code, see pic. I am assuming this is not stopping regens so is recommendation not to change, looks like a pain but it does seem like mine is ok, does do lot short runs as I stay scottish isles. Thoughts?
Also think my light clonk on right hand turns whilst pulling away is maybe now there, to a lesser extent, when pulling away in straight line possibly, so guess this might add weight to prop rather than drive shaft? thanks all
Post #717342 3rd May 2025 8:42pm
Page 3 of 3 <123
