![]() | Home > Technical (L322) > New 2012 Westminster owner, 3 months in after some advice |
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 709
I had the same quadry so what I did was cut off the compressed pipe clamp to the right angled plastic connector and replaced it with a jubilee clip, in that way it meant I could do the O ring removal and fitting to the plastic housing on the bench.
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48
sounds like a decent approach, you go with wee Dremel style cutting disc or careful hacksawing diagonally? |
If I remember the standard clamp is one that has some latching tabs that latch it in a loop and a special tool tightens it, so then you can just find the join and prize it apart using a small flatblade screwdriver.
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
If you go on ebay and search for the engine, you will see quite a few engines for sale that have good front end photo's that might point you in the right direction.
Managed to suss vacuum pipes and got everything else back together, topped up coolant, dash said oil was ok (double click cruise cancel button as was cold) and off I went out for a spin, all seems well, purring and no obvious leaks, happy days.
| toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 318
There is a parts catalogue (and workshop manual) in the wiki and that says FSE000030 front, FSE000041 centre and LR011706 to the handle.
Still not completely clear from that. Is it LR11474 and LR011706, one is for RHD and other is LHD or something, anybody had this and bought one of these, which is which?
Still not clear after doing search, anybody? thanks |
Many thanks, got her back together and running last week, no obvious leaks, got a cable to replace bonnet one but aint stuck that on yet, many many thanks for all the help. Will be getting onto knock (prop?) and bonnet cable when get chance later this week, great to be back going |
still not done bonnet release cable but being driving couple weeks now, not seeing any drips underneath and oil and coolant seem to be staying put level wise.
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851
Diabloam
This doesn't feel or sound like it is from the front though, also seem to be able to feel it through elbow on console etc, but sounds move about, did you feel it like that? |
Where you say:
| All times are GMT |
