![]() | Home > Maintenance & Mods (L322) > Suspension message 30 MPH |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8737 ![]() ![]() ![]() |
First thing to do is plug in your IID and follow the attached to read any faults, then I always export them via email to myself, then clear the codes and see what happens... |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 268 ![]() ![]() ![]() |
Thanks Pete - that export function is handy will have play. |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
I had that exact issue last month and the bouncy bouncy ride home was a little disconcerting to say the least |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I recently had exactly the same as in NobbyC's post, I had to lift the car to off road height to hear an air leak. I had to go from normal to off road height several times before I heard the air leak. |
Thanks chaps - one to look at when the crankshaft oil seal is sorted. |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Could be as simple as a height sensor.
Thanks Goldstar - it’s in the garage at the moment having a few pulleys and tensioner replaced, but will get them to interrogate the ride height sensors.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 340 ![]() ![]() |
deleted by author 2012 L322 4.4 TDV8 AB low mileage - a peach
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Had the same issue but a different fault with my AMK compressor which I think you have.
Popped into Bell Automotive this morning to get them to have a look at the suspension issue. It only occurs at 45mph+ and Graham said - "ah - dynamic response system, let's have a look at your wiring"
Tidied up the wiring and soldered some clean, neat connections to replace the dodgy repair previously carried out. Used full length heat shrink over the area and a grommet into the top of the suspension turret.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7976 ![]() ![]() ![]() |
No expert, but I think the “max 30mph “ type suspension fault relates to air springs and height sensors, not the adaptive dynamics system. Repairing the wiring obviously needed to be done, and good, but I don’t think that would throw the error you have. That throws an adaptive dynamics fault.
Thanks for the pointers - the car had been flashing up Adaptive Dynamics Fault at the same time as the suspension warning and the garage had previously diagnosed a faulty ride height sensor not giving a voltage output. There was a cross activation message on their Optimus (previously Autologic) system.
Indeed. You may have a mix of both, but in relative terms, if it’s a height sensor they are not daft expensive or too difficult to do. Consensus on here is to use genuine ones…. See what your garage says.
