Home > Maintenance & Mods (L322) > Suspension message 30 MPH
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
I am getting the suspension message after approx 10 miles of driving and the car goes into bouncy bouncy mode. It doesn't sag overnight, so I'm assuming it's not the air bags or valve blocks leaking ?
From my initial investigations and in terms of cost, there's the relay, then a compressor service kit, then the air reservoir and possibly corroded wiring to look at.
I have a GAP iid but not sure how to start interrogating the system to find the fault. Any pointers would be much appreciated.
Thanks
Jonny
Post #714392 19th Mar 2025 10:58am
First thing to do is plug in your IID and follow the attached to read any faults, then I always export them via email to myself, then clear the codes and see what happens... Thumbs Up
https://www.gap-diagnostic.com/support/documents/iidtool/ Pete
-Click here for Thread-
Post #714395 19th Mar 2025 11:06am
JonnyCJ
Thanks Pete - that export function is handy will have play.
Post #714396 19th Mar 2025 11:08am
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
I had that exact issue last month and the bouncy bouncy ride home was a little disconcerting to say the least Shocked . The problem was traced to a small split in the front airbag when the suspension was raised to full off road height but not obvious at the other lower settings or when parked overnight. Simple test just raise the suspension fully and listen for a slight hiss of escaping air
Post #714444 19th Mar 2025 7:17pm
Merchy
I recently had exactly the same as in NobbyC's post, I had to lift the car to off road height to hear an air leak. I had to go from normal to off road height several times before I heard the air leak.
Post #714449 19th Mar 2025 8:34pm
JonnyCJ
Thanks chaps - one to look at when the crankshaft oil seal is sorted.
Post #714454 19th Mar 2025 9:37pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Could be as simple as a height sensor.
I had this last week. Tyre place let my car down trapping the arm in the suspension (unbeknown to me). 2 miles into my run home red suspension, 30mph sign and a ride more bouncy than Zebedee's moustache.
Went to see if the sensor had flipped over but the arm had snapped. Change sensor, all good. What is your 4x4 screen showing? Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #714518 20th Mar 2025 8:09pm
JonnyCJ
Thanks Goldstar - it’s in the garage at the moment having a few pulleys and tensioner replaced, but will get them to interrogate the ride height sensors.
Appreciate the heads up as I know it can be an expensive exercise chasing down the issue.
Post #714520 20th Mar 2025 8:24pm
Range Rover L322
deleted by author 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #714545 21st Mar 2025 12:12am
Danwilderspin
Had the same issue but a different fault with my AMK compressor which I think you have.
I’ve had it twice in my ownership.
The exhaust solenoid on the compressor failed so it couldn’t vent so it blew up and then couldn’t release so it seemed to fill the bags . Changed the solenoid… problem solved for about two years…
Same fault this time not always 30mph sometimes just suspension fault… braved driving a little longer then I just heard the exhaust permanently venting as I was driving and ended stopping as it was on the bump stops… its seemingly failed the otherway this time… turns out the orings had expanded and weren’t sealing! A couple of pounds fix been ok for two weeks nearly fingers crossed Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #714823 25th Mar 2025 12:10am
JonnyCJ
Popped into Bell Automotive this morning to get them to have a look at the suspension issue. It only occurs at 45mph+ and Graham said - "ah - dynamic response system, let's have a look at your wiring"
He then explained to me how the dynamic response works (magnet on the top of the suspension turret) and showed me how my wiring had been "amended" in the past.
I could have been chasing my tail for ages on this, so looks like a hopefully simple and non expensive fix.
I'm on hols on Sunday, so they're going to take it in and sort the wiring, as well as giving the car a thorough clean underneath, followed by Fertan rust treatment for any rusty bits and then Dynax UC for the exposed bits and Dynax S50 for any cavities.
There's also a second oil leak towards the rear of the engine to be looked at, so hopefully I'll come back from hols with it all spic and span.
Post #715530 4th Apr 2025 11:39am
JonnyCJ
Tidied up the wiring and soldered some clean, neat connections to replace the dodgy repair previously carried out. Used full length heat shrink over the area and a grommet into the top of the suspension turret.
Went out for a test drive.
Previously the “suspension fault max 30 mph” warning had come on at exactly 45 mph and managed to get up to 60 and no warning !
“Hussar !” I thought.
Only for the warning to come on at around 60mph.
Progress of sorts. I think I’ve eliminated a permanent error at 45mph with the dodgy wiring to the front suspension and now have an intermittent error at variable speeds. This suggested to me a dodgy wire somewhere in the circuit which is activated when the speed is over 45mph and the wire is possibly shorted whilst going over a bump.
It’s being dropped off at the garage tomorrow en route to the airport and they are very good at tracking down issues such as this, so fingers crossed.
Post #715624 5th Apr 2025 7:30pm
mjdronfield
No expert, but I think the “max 30mph “ type suspension fault relates to air springs and height sensors, not the adaptive dynamics system. Repairing the wiring obviously needed to be done, and good, but I don’t think that would throw the error you have. That throws an adaptive dynamics fault.
Happy to be corrected but I’m pretty sure I’m right.
As someone mentioned above, when the fault shows again, have a look on the 4x4 screen and see what the car thinks is happening.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #715634 5th Apr 2025 9:37pm
JonnyCJ
Thanks for the pointers - the car had been flashing up Adaptive Dynamics Fault at the same time as the suspension warning and the garage had previously diagnosed a faulty ride height sensor not giving a voltage output. There was a cross activation message on their Optimus (previously Autologic) system.
Will see what they find when it goes in this afternoon.
Post #715640 6th Apr 2025 8:59am
mjdronfield
Indeed. You may have a mix of both, but in relative terms, if it’s a height sensor they are not daft expensive or too difficult to do. Consensus on here is to use genuine ones…. See what your garage says.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #715649 6th Apr 2025 11:48am
