Home > Technical (L405) > Deployable Tow Bar
MwestcrewRR
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Carpathian Grey
Deployable Tow Bar
Can anyone help me with how the deployable tow bar is supposed to function, or rather if the electrics socket is supposed to deploy.
When I press the button the ball slowly motors out but there was no sign of the socket. So I got under the car and the socket is there but it seems to be swung up out of the way on a pivot. I tried gently pulling it down but it seems pretty solid up there.
I’ve given it a good spray of penetrating fluid for the time being.
Thanks In Advance
Post #714415 19th Mar 2025 2:31pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Yes it is spring loaded to the opertional position, ie down so should drop. It will be seized and with the tow bar deployed you shoud be able to free it with gradual rocking. They seize really easily.
Post #714418 19th Mar 2025 2:48pm
MwestcrewRR
So does the tow bar normally keep it up in place?
Post #714422 19th Mar 2025 3:38pm
Yes - mine normally drops down as the tow ball does & it then gets pushed back up when it's stowed.
Post #714424 19th Mar 2025 3:49pm
Marmoset
United Kingdom 2016 Range Rover Vogue SDV6 Loire Blue
Had the same with mine that I picked up a few weeks ago. A liberal application of WD40 to the pivot of the socket for a few days freed it up.
Post #714460 19th Mar 2025 10:22pm
roel2018
Netherlands 2017 Range Rover Autobiography SDV8 Carpathian Grey
I am planning to mount an original LR deployable towbar (not the electrical foldable) on my 2017 SDV8 L405 I was wondering if I do need the body control module VPLGT0204? My car has the deployable side step option so I think I don't need it. The strange thing is that one dealer calculated this module and another dealer didn't.
Expensive module so just to be sure. 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #718593 26th May 2025 8:43am
