![]() | Home > Technical (L322) > Throttle Body Elbow / Pipe Part ID |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299 ![]() ![]() ![]() |
That green thing inside the throttle body elbow is the o ring, some folk on here have put in additional o rings because it does feel loose, others have used PTFE tape. I replaced my throttle body a couple of years ago and didn’t change the o ring and mine is fine.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 200 ![]() ![]() ![]() |
I also have a 2012 4.4 and my throttle body was leaking a little evidenced by oil misting. Following advice on here I purchased o rings for this and fitted 2. It's now seating perfectly and no longer feels loose or leaks. I have a couple spare and happy to post to you if you would like. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1001 ![]() ![]() ![]() |
yep - 3 x 75mm int diameter 3mm O Rings did the trick
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Who’s a clever lad & who’s stupid……I looked everywhere🫣🤭
