|  | Home > Technical (L322) > Throttle Body Elbow / Pipe Part ID |
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299      | That green thing inside the throttle body elbow is the o ring, some folk on here have put in additional o rings because it does feel loose, others have used PTFE tape. I replaced my throttle body a couple of years ago and didn’t change the o ring and mine is fine.
|  29th Mar 2025 9:54pm |
| Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 215      | I also have a 2012 4.4 and my throttle body was leaking a little evidenced by oil misting. Following advice on here I purchased o rings for this and fitted 2. It's now seating perfectly and no longer feels loose or leaks. I have a couple spare and happy to post to you if you would like. 2012 4.4 TDV8 Vogue Santorini black ivory leather | ||
|  29th Mar 2025 10:07pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | yep -   3  x  75mm int diameter 3mm O Rings  did the trick
|  21st Aug 2025 11:50am |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | Who’s a clever lad & who’s stupid……I looked everywhere🫣🤭
|  21st Aug 2025 12:58pm |
| Posting Rules
