![]() | Home > Technical (L405) > Do Deployable Steps Need Calibrating? |
fez Member Since: 24 Jan 2025 Location: UK Posts: 11 ![]() ![]() ![]() |
Hi Stuart, let me know if the trip to Sytner manged to resolve this, other than what you have mentioned haven't found anything about calibration for the steps. Thank fingers crossed it resolves it for you. |
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 19 ![]() ![]() ![]() |
I've had both mine done and fitted with OEM motors and hinges. I've just contacted my garage and he said they are just fit and plug in, no calibration.
Stuart did you ever manage to resolve the issue? |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 403 ![]() ![]() |
It's booked into Sytner to have it done. I'll update when done.
KN Member Since: 07 Jan 2025 Location: Chandigarh Posts: 14 ![]() ![]() |
Mine left step was stuck open. I thought of carbon brushes of motor stuck. Opened motor and replaced jammed bearing 6003zz of gear, driven by motor. I separated motor and hinge. Also operated without hinge for testing. What I did was....There is millinig on the motor shaft while motor is not filtted door is open and step is fully deployed fit the motor and put the tapered piece in between motor and hinge and tighten the LN key bolt. Standard 2000 (Rover Sd1) 1989 - 1992
Mine is L322. I don't think it needs calibration by any software. Standard 2000 (Rover Sd1) 1989 - 1992
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 77 ![]() ![]() ![]() |
There's a chance they assembled them wrong and the wedge that locks the shaft in isn't seated correctly. I swapped the motor on mine with no calibration required, they work on resistance to detect when the step is at the end of it travel |
So trying a couple of things and just come to the conclusion that the old motor and the new ones are about quarter of a rotation from where they need to be.
Quick update, used a 12v drill battry on the motor and moved it to fully deployed and then switch the wires and retracted the step so that works perfectly, plugged it back into the car and still reacting to instructions that are not their its like the moto sensor it out and no way to reset it if what I have been told is correct.
Wonder if removing the control module and reengaging might do something? Any ideas |
Just a quick update to this.
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 36 ![]() ![]() ![]() |
Does it work correctly every time when the back door is opened? If so the problem may be the microswitch in the door latch. |
Not on its own, no.
noone Member Since: 05 Apr 2025 Location: Florida Posts: 75 ![]() ![]() |
There is no calibration involved. I just installed Chinese deployable steps on a L460 that look just like the real thing, $1000 USD shipped before the tariffs went into effect.
The main dealer thought this, they had the steps off and reinstalled them, and it still does it. 2017 4.4 SDV8 Autobiography in black
