![]() | Home > Technical (L322) > Suspension Bushes check and replacement |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Hi,
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Brilliant cheers Strider, I will give that a go. I don't think mine has seen much salt considering it's age so I am hoping it comes off okay, I have some penetrating oil somewhere, or a big hammer failing that.
Good morning,
Thanks Peter, I will do the rears first then give the fronts an inspection. Nothing on MOT about the front, but I need new tyres all around and would like to avoid scrubbing them in the first year!
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
For info Lemforder were the Original Equipment supplier for the bushes - so as good as they get & definitely a lot better than some of the pure aftermarket suppliers.
"On the your comment about tightening, just to make sure I understand correctly, the suspension should be close to it's normal running height prior to tightening, and this is to allow the bush to be in its relaxed state most of the time, rather than always slightly twisted ?"
Brilliant thanks guys, the parts have just arrived, so will give it a go! |
Got it all sorted today 👍 cheers for the help. Hardest part was the circlip removal... Seemed to be fused to the hub!
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
Or short it out? |
Is that literally cut the cable and solder wires together? |
