![]() | Home > Technical (L322) > 4.4 tdv8 lacks low end power but no fault codes |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
Might not be related but I recently had an issue that was there for ages but didn't throw a fault until I went up a very steep hill. I had a split in one donut rubber where the clamp attaches. Once I replaced all 4 with some locally sourced silicon tube I haven't heard any weird noises. I also had an issue with airbox screws being rusted and their being a gap where the filter sits.
Defender44 Member Since: 01 Dec 2023 Location: Northampton Posts: 19 ![]() ![]() |
Thanks for the suggestions, i’ve actually already purchased some silicone hose to replace them with when I do the oil cooler.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
Just worth checking to see if either rear wheel is getting hot.
Thanks Baltic Blue,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
The engine will only go into limp mode or show fault codes when a problem is detectable! If the split hose is not loosing or gaining enough boost then it won't detect it yet sir...
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Just a maintenance thought….
Already planning the gearbox oil ready for its next caravan pulling duty in a few months time .
Thanks for the suggestion, I’ve just got the caravan home and didn’t push it hard until the last few miles. So far nothing, no codes and I did push it…will get the under tray off and see if I can see anything that looks like a split pipe. |
