Installing a new filter and I’ve got stuck with the water drain connection.
I’ve installed the knurled metal cap at the bottom of the filter with the new seal, however I can’t get the water drain connection to stay on the round spigot on the cap.
There’s a threaded bit that come out if the cap centrally - I assume that’s not needed ?
There’s right angled rubber pipe that goes to the drain tube has a metal tube in it. I was hoping that would either slot into, or around the spigot on the metal cap, but they appear to be the same diameter.
Guidance gratefully accepted !
Thanks
Jonny
