![]() | Home > Maintenance & Mods (L322) > Centre vent trim removal |
JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 20 ![]() ![]() ![]() |
Hi - did you manage to remove this? I need to remove mine too. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
IIRC two little plastic clips down each vertical side, funnily enough they are the same spacing as the old radio removal tools, the U shaped one, which work well in removal, you have to move the little clips, which are moulded in and not separate, towards the centre line of the vent, when all four are moved you can pull it out, easier to do one side at a time, they are very fiddly so take a time, especially if you don't want to break them... Pete
This tool, it will hold the tabs back if you get it in the right place....
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 268 ![]() ![]() ![]() |
Really appreciated - thanks Pete |
Thanks Hayland, appreciated. I've bought a complete Autobiography interior inc headliner and will be starting with this piece. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
Pete - are these tools for removing the trim piece - H shaped, or the centre vents ? |
The vents, IIRC the trim comes with it but it is a few years since I've done it on a 322
I've just checked with a friend and he's advised that the top dash panel and stereo needs to come out as the stereo sits on top of the trim piece. Not difficult but time consuming! 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
As I said it's been a long time since I've done it but I don't think you have to take the radio out to remove the air vent....
Hi - sorry, shouldn't have been clearer. Stereo removal is required for the H trim piece, not the vent. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
