Home > Maintenance & Mods (L322) > Centre vent trim removal
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
My centre vent surround - the cream coloured bit that goes round the vents and under the display unit is a bit grubby on the top where countless hands have rested on it whilst using the touch screen display.
I’d like to give it a thorough clean and take it off to do this. Is this a simple job ? The dash will be coming off soon and the display unit switched for dual view, but ideally I’d like to do it prior to that.
Post #716065 13th Apr 2025 12:40pm
JedY
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Sumatra Black
Hi - did you manage to remove this? I need to remove mine too. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior.
Post #716863 26th Apr 2025 10:32pm
IIRC two little plastic clips down each vertical side, funnily enough they are the same spacing as the old radio removal tools, the U shaped one, which work well in removal, you have to move the little clips, which are moulded in and not separate, towards the centre line of the vent, when all four are moved you can pull it out, easier to do one side at a time, they are very fiddly so take a time, especially if you don't want to break them... Pete
Post #716869 27th Apr 2025 1:34am
This tool, it will hold the tabs back if you get it in the right place....
 Pete
Post #716870 27th Apr 2025 1:37am
JonnyCJ
Really appreciated - thanks Pete
Post #716871 27th Apr 2025 7:50am
JedY
Thanks Hayland, appreciated. I've bought a complete Autobiography interior inc headliner and will be starting with this piece. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior.
Post #716872 27th Apr 2025 7:57am
JonnyCJ
Pete - are these tools for removing the trim piece - H shaped, or the centre vents ?
Post #716875 27th Apr 2025 8:40am
The vents, IIRC the trim comes with it but it is a few years since I've done it on a 322
PowerfulUK videos on you tube are pretty good, they do gloss over some PITA bit's, the worst being the centre console hinged lid...!! Pete
Post #716883 27th Apr 2025 10:42am
JedY
I've just checked with a friend and he's advised that the top dash panel and stereo needs to come out as the stereo sits on top of the trim piece. Not difficult but time consuming! 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior.
Post #716891 27th Apr 2025 12:37pm
As I said it's been a long time since I've done it but I don't think you have to take the radio out to remove the air vent....
 Pete
Post #716892 27th Apr 2025 1:42pm
JedY
Hi - sorry, shouldn't have been clearer. Stereo removal is required for the H trim piece, not the vent. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior.
Post #716893 27th Apr 2025 1:44pm
