![]() | Home > Technical (L405) > Locked In Drive, Engine off, |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I’m pretty sure that under the bottom of the cup holder there is a red lever thing that if you pull it it puts the gearbox in neutral. That said, hopefully the issue you currently have won’t stop it working.
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 81 ![]() ![]() ![]() |
Cheers, we've found that already, suspected drive selector solenoid issue.
https://www.fullfatrr.com/forum/post706405.html
Ah, ok, so figured then you can get it in neutral to start engine but can’t move gear selector. I’m stuck with that one without more forum searching, not had that issue I’m afraid.
So, Here's an update if you have an L405 made before 2016, apparently the electronic motorised gear selector can be re-furbished, there are a handful of companies in the UK that do it, you just have to get it out and send it to them.After 2016 they are a sealed unit.
So, motorised drive repaired and refitted(£356), I purchased some foil tape, to repair the razor edge of the cupholder sliding tray, but it looked a bit naff, and I managed to break off a couple of the plastic rivets that hold the trim down, so I thought, WTF, get the whole thing off, leaves a 2-3mm gap around the whole tray, but luckily mine has no damage to any of the edges, and personally I think it looks pretty good!
