Home > Maintenance & Mods (L322) > Car complete loss of Electric power
disco 3.5
Hi can anybody advise me please, I’ve just lost complete electrical power, won’t even lock, battery has been going flat, this morning the dash board lights all came on turned key and no starter motor at all, so I’ve just charged it up and turned the key and all power has gone can’t even lock it, any ideas 💡 LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #717011 28th Apr 2025 6:37pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Earth strap? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #717012 28th Apr 2025 6:48pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Big fuse joining fusebox to power, or chassis. Very common on BMW cars. Its a wide thin piece of Alluminium.
Post #717016 28th Apr 2025 6:52pm
Balloonengineer
I had a complete electrical loss recently, and it was alternator failure as it shorts the battery.
A Censored of a job with a TDV8 4.4. If the top 1/3 of the fan shroud is cut off it saves about a day of work as you can then unscrew the fan
then you can get to the alternator. (I believe earlier models were in 2 pieces). then join the shroud back together with a plate and self tapping screws. I think with this small mod I could now do it again in a day. Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #717102 29th Apr 2025 7:05pm
Dolphinboy
check there isn't a back up battery installed in the rear right compartment where you normally keep the tow hitch. I had one (put there by previous owner) and it drained the main battery and I lost all power whilst driving.
Post #717150 30th Apr 2025 10:57am
