![]() | Home > Maintenance & Mods (L405) > Park Assist using IidTool |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 835 ![]() ![]() ![]() |
Interesting also to see if and how LDW can be changed to LKA... |
I managed to enable Lane Keep Assist! This IIDTool is incredible!
The journey of discovery continues! I found the settings to enable the Adaptive Driving Beam. Up until now, I only had access to the Auto High Beam option, which worked well by dimming the lights for oncoming vehicles. But that got me thinking—what exactly is the advantage of Adaptive Driving Beam? The manual doesn't explain it clearly. |
The submenu before was just Land Departure Warning with on or off, it has changed after the activation to LKA with vibrate or assist, but I have yet to check if it really assists, as in town it is impossible to use (speed too low)... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
is it a G4 iidtool version you're using? ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6785 ![]() ![]() ![]() |
Mine is a G3 Stan Got - 2017 SDV8 Autobiography in Loire Blue
Yes, Stan, the G4, it’s an awesome tool! |
thanks for that adara.. |
goodknight Member Since: 13 Nov 2024 Location: Berkshire Posts: 2 ![]() ![]() |
Did the changes work for you ie. Lane keep assist and steering assist? |
Being away from the car, I simply didn't have the opportunity to check, but will do this weekend... |
I finally had the opportunity to test Lane Keep Assist, and it does work. Once the car exceeds 60 km/h (37 mph), the lines on the dashboard turn green, and the system begins to correct the trajectory. You can even remove your hands from the steering wheel for up to 10 seconds. However, I’m not sure if it's supposed to function this way—it doesn’t keep the vehicle centered in the lane. Instead, it swings from one side to the other, only activating when approaching the edges. That said, it does its job.
