![]() | Home > Technical (L405) > Possible Turbo issues |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2760 ![]() ![]() |
Faults would be stored if the valve isn't where it is supposed to be as its position is monitored, including at idle. L405 D350 SE Carpathian Grey D5 19" rims |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1356 ![]() ![]() ![]() |
Yes Graeme thanks. No codes so I presume it is working correctly. |
iainvr4 Member Since: 16 Mar 2013 Location: glasgow Posts: 47 ![]() ![]() |
Hi Ash, Did you ever get to the bottom of this? It is virtually the same story as my car. I don’t get the oil filter thing as when I checked mine there is no spring there and can’t see that someone has deliberately removed it. I have the same oil issues, drained over a litre out the intercoolers last night and the same fault codes. The turbos have been removed and tested but all ok. Thanks Iain |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi Ian,
Hi Ash,
Oooh - wait 1... Your profile shows a 2004 TDV8..? If thats true, the set up might be completely different.
Thank you Ian for giving me the nudge to go take a look at mi e to see if I can get closer to the issue.
Hi Ash It is a 2017 4.4 I have just not updated my profile on to my 3rd RR. It was possible to remove both the turbos but did need a lot of patience there is a few really tricky bolts to get out and you are essentially working with only one hand and it took me a bit of time as I only managed an hour or so after work in between the bad weather as the car was on stands in the drive. Mine is doing the exact same as yours when you drop off the boost that’s when the light comes on. Checked it with live data and it was showing at 100% when it should of been 0% I’ve stripped the sensor out it and about to try it with the live data to see if I get a lag. The valve is moving totally free unless it is when it warms up it sticks the mechanical parts is soaking just now to free off any carbon. I’m not sure what the script is with the oil filter as surely the plate can’t be missing as it you’d think when they done the cooler they would have noticed. I can’t see any difference in part numbers although there is a supersession so would if that’s the change. I’m not sure whether to order one and then just compare the 2 of them. Thanks |
Did they change these on later models? I have an oil issue similar to the OP check my filter housing and there isn’t a plate there nor a rubber grommet. Thanks |
Here is the picture of it |
Apologies Ian. Was going off your profile.
Yours should look like the top pic. The bottom one is with the clip/spring removed. Ash ------------------------------------------------------ 2022 SDV8 AB 2016 TDV8 VSE 2011 TDV8 VSE 2006 V8 Vogue 2002 2.5 Vogue |
Just now mine looks like the bottom one 🤦🏼♂️
The concerning thing is where the hell has it gone and when??? |
