Home > Technical (L405) > Possible Turbo issues
Page 9 of 9 <123456789
iainvr4
2004 Range Rover Vogue Td6 Java Black
comports wrote:
iainvr4 wrote:
Here is the picture of it
Yours should look like the top pic. The bottom one is with the clip/spring removed.
Hi Ash
Give you an update on my progress I have changed the oil cooler so time will tell if that cures my oil issue.
Restricted performance turbo codes I have carried out a live data check and when I am coming off the power the commanded value was 0% and actual was 100% on the turbine shut off valve and on pinged the warning. Took the valve off and check led it manually and there was a slight delay but the valve moved freely, stripped the sensor out it and it was the same moved freely but a delay through the live data so fitted a new shut off valve as I could get a sensor. Taken it for a drive with 4-5 hard accelerations above 3k watching the data and the actual and requested was spot on and no lights so longer test drive tomorrow and hopefully šŸ¤žšŸ» I’m
On the right track.
Post #719731 13th Jun 2025 10:45pm
comports
Thats great new Ian - fingers crossed for you - I wish you were closer to me..!
I have no real clue what I'm looking at - I don't think the 'actuator' is the same thing that you were looking at although that part does seem quite hard to push (certainly not easy by hand) and, on a couple of occasions, did stick in the 'on' position and required me to pull it back.
This is the part i'm talking about - which I don't believe is the CSOV that you are looking at.
The rod (as shown with the arrow) is the part that will push with some pressure.. you can hear a 'glunk' when fully depressed which sounds like its closed a metal flap..?
I believe the articulating arm is this part..? (which I can't see)
Am I looking in the wrong place here - given the fault code I had was this...
... Any one wanna buy a 4.4 SDV8 AB....... I wanna 5.0 V8 petrol... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719740 14th Jun 2025 10:19am
iainvr4
Had a further road test today and all ok up to 4K rpm and no issues. The valve from the faults codes which where the same as mine is the shut off valve bolted on to the back of the secondary turbo. The CSOV doesn’t have a position sensor so it wouldn’t know its position or if stuck but wonder if the MaF sensor faults is a sign of it sticking as it would cause a the passenger one to get a reading when it shouldn’t.
Post #719741 14th Jun 2025 10:32am
GraemeS
Australia
That's certainly the turbine shut-off valve, not the CSOV. L405 D350 SE Carpathian Grey D5 19" rims
Post #719742 14th Jun 2025 11:28am
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
kevinp wrote:
Ok mate. Thanks.
Just read in the workshop manual that if the car is left idling, the secondary turbo will activate every 3 minutes for lubrication. So thanks for pointing it out.
Does anyone know if this was the case with the L322 4.4 2011 or introduced with the L405s?
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #719906 17th Jun 2025 2:33am
comports
Hi Gang,
Hoping I can get some time to actually fix this issue once and for but appreciate some more advice if possible.
I still get restricted performance sometimes (but not always) and managed to get another set of error codes - hoping someone can make sense of it all.
Seems to still pull fine on acceleration and at that point the live data showed both commanded and measured opening position of the shut off valve was 99.6%, but when I lift off i get the bong.. had live data via IID showing the below.
This was taken after acceleration, turbo kicked in, when I backed off I took the reading. Looks to me like at the point I stopped ā€˜demanding’ the turbo the shutoff value remained almost 70% open…
Followed up with error codes for the same event I got…
Further suggesting that something is stuck -
But now the data tells me
1. The shut off valve seems to stick open
2. Talks about Solenoid B and
3. Suggests the Actuator is sticking..
Big Cry Big Cry Big Cry
Can anyone shed any light on what actually needs to be swapped out for a new one please?
Thanks as always Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #720280 24th Jun 2025 8:01am
