Home > Technical (L322) > Please help me! 2012 Westminster
Ryanc
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi all!
Big Cry
I am in real need of help.
Had a vibration on my 2012 L322 4.4 TDV8 Westminster
My rear propshaft was obliterated (the centre rubber was completely destroyed and missing).
Have replaced:
Replaced rear prop shaft which reduced the huge vibrations at speed
Then replaced:
All shock absorbers with Biltstiens
All Air Springs with Dunlops
All front arms & bushes
All 4 tyres with brand new scorpion zeros 255/50/20 on original wheels
Replaced 1 wheel that had a buckle
Had all 4 wheels road force balanced
Tracking done twice
Front drivers driveshaft and knuckle & bearing changed
Front brake discs and pads changed new brembos
2 front brake calipers changed
Rear drivers caliper changed due to bleed nipple
Car is still whirring as you pick up speed and vibrates through the steering wheel
Does this in neutral and even if accelerating or decelerating…
Have now changed front diff oil, can’t see any bits of metal in there, it was gunky on the plug.
Changed engine oil for recommended Shell Helix Pro stuff.
Changed brake fluid.
Also, checked front prop and can’t see play in it, it only moves slightly back and forward on the rubber.
I can’t feel play on the driveshafts or move the wheels when off the ground (thinking bearings)
Getting a bit fed up now! Please help if you can!
Thanks,
Ryan
Post #716791 25th Apr 2025 8:41pm
kevinp
What mph does it start doing it? How many miles has it done.
Why did you change the front right driveshaft? Could the left one need changing as well?
What does the colour of the power steering fluid look like.
Post #716792 25th Apr 2025 9:40pm
Ryanc
Hi thanks for replying.
It has about 115k.
The vibration seems Audible from almost 30mph and the vibration worsens as you speed up quite bad at 70mph.
The front right knuckle & driveshaft hadn’t failed but I had to change them due to ball joints not coming out.
I’ll check the power steering fluid in the daylight and feed back.
My next port of call was going to be looking at the front propshaft (maybe it’s out of balance or something). Or yes, thought maybe a front left issue with bearing or driveshaft). Not sure how to tell if it’s an issue with the diff or transfer box…..
Many thanks for your help.
Post #716795 25th Apr 2025 10:30pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Silly question, have you checked tyres and wheels for buckles? I had nasty vibration turned out the inside of one tyre had a bulge, 2 new tyres later vibration gone.
Post #716796 25th Apr 2025 10:35pm
Ryanc
Thanks,
Yes have changed the tyres to brand new ones after some part worn changed on the rear and found 2 buckled wheels. One replaced by the good spare and I bought another wheel.
The new tyres were road force balanced and wheels double checked today - still have the problem unfortunately…..
Post #716799 25th Apr 2025 10:51pm
kevinp
Is it worth swapping the front wheels to the back and see what happens?
Post #716802 26th Apr 2025 12:00am
GraemeS
Australia
Does the vibration increase with road speed or engine speed or engine load, indicating drive-line or engine / torque converter issue?
Can the fan be readily moved by hand with the engine not running? L405 D350 SE Carpathian Grey D5 19" rims
Post #716804 26th Apr 2025 1:51am
Ryanc
I’ve tried swapping wheels around but still get the vibration.
It increases with road speed . Engine load, braking, cornering etc doesn’t change it.
Will check the fan shortly
Thanks
Post #716815 26th Apr 2025 9:15am
GraemeS
Australia
Has the transfer case oil been checked? L405 D350 SE Carpathian Grey D5 19" rims
Post #716826 26th Apr 2025 12:13pm
Ryanc
Had the car up in the air today.
There is some rotational play in the front prop and when turning the rear wheel there is a rubbing noise at one point (same point every time)… mechanic is going to look in the rear drums to check brake shoes and rear disc run out. Also going to check the prop bearings.
I think there is a bearing noise (front left) with the vibration when I circle a roundabout……
Will feed back if anything found.
Changing the transfer case fluid hopefully too
Post #717031 28th Apr 2025 10:59pm
RobsterPC
Sounds like you're doing a great job replacing parts. It will be great once you nail it down. Random one, there aren't any wheel spacers on it are there? Even hub-centric ones can incite vibrations through the car.
If you've balanced wheels and cleaned all the faces (wheels and disks), its less likely to be the wheels. You can swap wheel front to back to see if the vibration moves. Are you happy the disks are all running true?
If its as bad as you say, can you get it on a lift and run it through the gears on a lift to see if you can find the culprit that way? I don't recommend this on stands, it could go very wrong it if falls of at an indicated 70 mph!
Post #717232 1st May 2025 4:24pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
maybe wheel bearing ?
Post #717241 1st May 2025 6:31pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
My Wife's P38 had a similar problem which turned out to be the viscous Fan. Does the vibration happen when reving the engine in neutral? Something else to eliminate. 🙂
Post #717244 1st May 2025 7:18pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I have discovered an issue with my Westminster which is giving me a vibration, albeit, it is most noticeable when pulling away and at low speed. Investigations by my Rangie specialist has uncovered some wear in a rear hub knuckle which was allowing a bush to slide out of position. That was affecting the rear wheel camber and causing the vibration.
Note sure if this is any help.
Post #717355 3rd May 2025 11:43pm
Ryanc
Thanks - I have now had front wheel bearings & hubs & cvs replaced also handbrake shoes and guides. Still an issue. Really getting frustrated now!
I rekon it could be coming from the rear as everything at the front has been replaced.
@Proftinkerpot - Is your specialist in the UK? My rear tie rods need changing as one rear wheel is apparently sticking out at front (camber is ok).....
Doesn't happen in Neutral unless the wheels are turning. I can hear an audible whirring almost from standstill as soon as the wheels are turning, still there in neutral.... wonder if rear bearings could cause this but not sure what it would cost to have rear bearings and toe links changed\?
I must add, it doesn't seem that anything changes when turning/swaying. the whirr/vibration is the same. I do feel as if when I accelerate hard the vibration is much less and when you let of on decceleration/coasting it is the worst......i could be mistaken though. When I accelerate away gently it's noticeable at 20/30mph quite obviously. obvious at 50 and then worse and worse at speed it seems.
Post #718116 17th May 2025 8:02pm
