![]() | Home > Maintenance & Mods (L322) > Aggravating Wheel Wobble |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Have you had the front brakes checked for a sticking calliper, or even if they’re full of crud they could be causing it to stick slightly and give a wobble. I had this on one of my l322’s and it turned out to be a sticking brake. |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851
Dodgy wheel bearings can also make moaning / humming / grinding sounds
| Faversham Member Since: 09 Mar 2023 Location: Farkhem Hall Posts: 15
Thanks Dave I did ask the Indy to check that recently and they said no issue. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan ************************************************* 2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current 2006 L322 Vogue SE 3.6 Java Black/Sand - Current 2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - Dead & Gone 2018 Discovery 5 - Gone 2017 Discovery 5 - Gone 2016 Discovery 4 Landmark - Gone 1997 P38 Vogue - Gone 1988 LR 110 V8 County - Gone 1981 LR 109 Stage 1 V8 County - Gone |
Unnecessary quote removed
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
Did you tighten the control arm bolts with the weight of the car on them? |
If the issue started after the control arms were replaced…that’s where I would be looking first |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575
Agree with what Rambles just said ^^^
Agree with suggestion above that it could also be worn / out-of-adjustment rack (pre-load).
No it started at about the same time if I recall, replacing one of the control arms was an attempt to resolve it. One had been replaced at the same time as the brakes and another at a later date. Both made no difference. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan ************************************************* 2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current 2006 L322 Vogue SE 3.6 Java Black/Sand - Current 2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - Dead & Gone 2018 Discovery 5 - Gone 2017 Discovery 5 - Gone 2016 Discovery 4 Landmark - Gone 1997 P38 Vogue - Gone 1988 LR 110 V8 County - Gone 1981 LR 109 Stage 1 V8 County - Gone |
@D3jon
A sticking calliper could have caused your original problem of warped discs, so could be the problem once again.
| Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 153
I’ve got much the same issues that you have and it’s driving me crazy! I’ve had two trusted garages check it over and they can’t find anything wrong. Hunter alignment done a few times all green yet I have to steer slightly to the right to go straight unless the camber slopes to the right.
I also had my tyres "blocked" on the outer edges which suggests play somewhere. Its going in for some other stuff tomorrow so if they find anything, I'll report back. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan
Well that's frustrating.....
| All times are GMT |
