![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 190 ![]() ![]() ![]() |
Interesting that you should mention the ambient temperature. I've had a TDV6 for almost 2 years and being of a certain age I have monitored my regens using the Kot Kit.
steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 20 ![]() ![]() ![]() |
Recently noticed that my 2012 4.4 TDV8 dpf was filling up quickly but assumed it was because I've only been taking short journeys recently, unfortunately.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
Hardy,
1) Your fill rate is not significantly out of the ordinary. I would not be concerned at the fill rate yet. 2) The EGR valve is monitored by sensors which will alert you if there is a fault — attempting to diagnose based purely on degree of valve opening and timing is unlikely to yield meaningful insight. 3) The fact that the DPF drops to 4.5 grams following a regeneration suggests the system is functioning correctly. 4) If you remain concerned, consider running the IIDTool while driving — this will give you real-time data and a better understanding of the system’s behaviour, helping to identify whether further investigation is warranted. It's easy to overanalyse DPF function, as it’s not always intuitive — this often leads to chasing non-issues. I would recommend simply driving as normal and, if another “DPF Full” yellow warning appears, begin monitoring at that point. Hope that helps! . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
That does help, thanks.
Different engine Steve but some of my ramblings might be of interest.
JAD Member Since: 19 Oct 2020 Location: Wirral Posts: 34 ![]() ![]() ![]() |
I have the red Dpf full message and restricted performance. Is there anyone on the Wirral with a Gap tool that could help me out with a forced regen. My Icarsoft tool won’t complete either a new Dpf or forced regen cycle. |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 249 ![]() ![]() ![]() |
Yep - I’ve got one you’re welcome to borrow. Only in Heswall, but don’t know if you can force a regen on the car it’s not coded to, or whether it just reads codes etc.
