Home > Maintenance & Mods (L405) > oil cooler replacement how to?
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
All good we were able to use the plastic connector off another pipe stated in previous picture. Maybe just these plastic clip connectors should just be made available as they have a tendency of breaking as soon as you touch them. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #655143 30th Jan 2023 3:27pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
I have this job to do on mine, very slight leak and smell.
Do we fit a genuine oil cooler or are there better pattern parts?
Post #699249 1st Sep 2024 3:03pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I fitted a Nissens one. 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #699299 2nd Sep 2024 7:44am
zenman63
Well I did this last weekend, all went well, nothing broken and only used new genuine gaskets, revised apparently I guess Viton, expensive at £72 for both oil cooler and the throttle O ring, I have the turbo O rings of a guy on here.
Biggest job is the cleaning of the plenum, thick with soot so soaking overnight in drain cleaner from B&Q, it works amazingly and came out like new.
You do need a large plastic tub for it and prepare to get very dirty and you need to plan on taking the black gunk to the recycling tip in drums.
The soot is just amazing at just 60k.
Post #717507 6th May 2025 6:23pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Excellent job 👍
Can you share details of the drain cleaner you used? I used oven cleaner but it was still hard going.
Post #717555 7th May 2025 11:53am
zenman63
This is what I used, soak over night and it washed clean.
Post #717561 7th May 2025 1:05pm
Richie N
Great, thanks 👍
Post #717565 7th May 2025 2:30pm
