Home > Technical (L405) > P400e Engine Sound - Does this sound normal?
rk7
United Kingdom 2016 Range Rover Vogue TDV6 Waitomo Grey
Hello!
Asking for my fellow P400e owners to confirm if this is how normal P400e sounds?
My P400e (new to me) had variable valve solenoid error codes, which I replaced (both) with the new newer ones (3 holds designs) and the error codes are now gone. However, I am not sure if this is how the engine sounds normally.
To me it has a bit of tappet like sound from the top and front of the engine and I am also concerned if it's the timing chain. No error codes in PCM. Idles fine.
There is also slight hesitation (sometimes) when setting off once warm at lights...etc (if not setting off in EV), which is why I am checking if this is normal or if I should get this professionally looked.
I've always looked after my own cars including my other TDV6 L405 but with the timing chain on this one being at the back I don't think I will have another choice if this isn't normal haha.
Video link: https://imgur.com/a/u05yE23
Thank you all for your help!
Post #717815 12th May 2025 5:26pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
That sounds about right. Also, the hesitation at lights happens too...
Post #717816 12th May 2025 5:37pm
rk7
That’s a massive relief. So are injectors on these really loud or something?
Thank you.
Post #717818 12th May 2025 5:43pm
