![]() | Home > General (L405) > What year did this very useful feature get removed |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3925 ![]() ![]() ![]() |
I’ve been looking for a newer L405 but none seem to have this opening pocket, useful for sunglasses etc but they don’t seem to have it
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
Yes, I have them in my 2017, just perfect for His n’ Hers Samsonite Compact Brollys! |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
It's no longer on MY18 onwards. They have a single compartment under the cupholders instead. Only Range Rovers since 1988 |
Thanks guys it definitely wasn't in the "Fifty" I looked at but that was much newer. Geoff |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
This space is inaccessible with cups in the holders and the cup-holder tray doesn't stay still when refitting a cup. IMO its only good for a secret hideaway, not for general use. L405 D350 SE Carpathian Grey D5 19" rims |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3804 ![]() ![]() |
They lost the door compartment with the 18my when they put the larger seats in and the seat controls moved from the squab to the door cards 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I never understood that, it was change for changes’ sake IMHO.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 860 ![]() ![]() ![]() |
Moreover, in my opinion, relocating the seat controls did not interfere with that compartment. If you remove the panel covering it—which is quite easy—you can see that there's nothing inside. Perhaps it was simply a cost-cutting measure.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
Don't know if it works for the post 2018 but powerfulUK do a conversion to put it in lower spec early ones... |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 149 ![]() ![]() ![]() |
That's good to know - the lack of this feature is a bit of a deal-breaker for a newer L405 for me.
By the way, those beautifully crafted 27cm Samsonite brollys (SKU 108979-1041) with proper real grained wood handles are still available for £39 each from:
I’ve had both and would rather have the centre console cubby under the cup holders - it’s got more useable space, it is lit and has a charging port / power supply in there.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2066 ![]() ![]() ![]() |
No it doesn't as it says; 'Which vehicles will this fit? This item WILL fit the Range Rover L405 models from 2013-2017 This item WILL NOT fit the Range Rover L405 models from 2018 -2021.' |
