Home > Technical (L322) > 322 n62 oil pressure light
Shook1
United States
Hey all, Christopher and Vera sent me. Picked up my 4th LR/RR recently. 05 RR hse with bmw 4.4. I know people hate this engine, but mine seems to run excellent with 160k. Vehicle was well maintained. Only concern is an occasional oil pressure light at idle. Oil pressure seems great though and plenty of oil flinging around valve covers. I know my bmws had issues with collapsing oil filters, so I immediately suspect this. But on my particular RR the oil filter housing is remote (located near radiator) and no matter where I go for a replacement I get given the wrong one. The filter I keep getting given has a plastic core and hollow bottom paper filter, but the one I need has a metal core and threaded bottom. This doesn't look to be an aftermarket oil filtration setup or anything, what gives? I'd really like to get this filter replaced. I'm also stuck dealing with some canbus issues and invalid rode height but that's all for another post. Love these old girls. She really feels like she carrying you gently down the road, in whatever condition. A whole different driving experience. (Protip, don't do a coil conversion to yours, I've had 4lrs, one with AB coil kit, and it destroys the LR/RR experience on highway completely, off road is alright but on road it's a complete molestation).
Well thx for any help, and ty for the service manuals. Great site 👍
Post #718183 19th May 2025 5:17pm
Shook1
United States
Oops Christian. 😆
Post #718196 19th May 2025 10:36pm
p38arover
Australia
Small correction to your typo. It's an M62, not N62. Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #718203 20th May 2025 4:36am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Just to check, the L322 M62 has a remote oil filter housing that, if you look in the engine bay, is behind the top right of the radiator. It takes a 'paper' style cartridge inside it which sits around a removeable plastic centre as seen here:
The later Jag AJ 4.4 V8 ('05 onwards) engine takes a spin on metal canister which sits near the bottom centre of the radiator, below the crank pulley, seen here at the bottom of the diagram:
I've not heard of a different set-up on LR M62 engines. You can get adapters to go on the side of the block for spin on metal canister filters for other BMW M62 engines but not seen one on the L322 as there's probably not space to fit it.
Post #718354 22nd May 2025 12:57pm
p38arover
Australia
The socket size for the oil filter cap is 36mm. The oil filter you need is the LPW500030 like this:
https://klr.com.au/land-rover/range-rover/...v8-petrol/ Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #718355 22nd May 2025 1:15pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I had this on tickover. Best solution was to drop the sump plate, remove the pickup and strainer, and clean the strainer using a sharp pick. If the guides have previously gone then there will be bits in the strainer restricting the oil flow. Easy job to do.
Regards
John
Post #718654 27th May 2025 12:36am
p38arover
Australia
The other things you may need are the filter housing rubber mounts. They do fail and tear apart leaving the oil filter housing hanging. 2 off part no. LYD000010
https://www.roverparts.com/filters/oil-fil...zNDw8QawqM Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #718656 27th May 2025 4:45am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Change your filter for a MANN filter
https://www.mann-filter.com/ph-en/catalog/...ilter.html
And while at it, replace the oil pressure sensor
https://clipzmotorsport.com/shop/e46/conve...re-sensor/
Finally, make sure the conical shaft on which the filter is attached is fully screwed down and the bottom of the oil filter housing is free of debris
Post #719018 2nd Jun 2025 12:28pm
