|  | Home > Technical (L322) > 322 n62 oil pressure light |
| Shook1 Member Since: 19 May 2025 Location: Maine Posts: 3    | Oops Christian. 😆 | ||
|  19th May 2025 9:36pm |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587    | Small correction to your typo.  It's an M62, not N62.   | ||
|  20th May 2025 3:36am |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419    | Just to check, the L322 M62 has a remote oil filter housing that, if you look in the engine bay, is behind the top right of the radiator. It takes a 'paper' style cartridge inside it which sits around a removeable plastic centre as seen here:
|  22nd May 2025 11:57am |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587    | The socket size for the oil filter cap is 36mm.  The oil filter you need is the LPW500030 like this:
|  22nd May 2025 12:15pm |
| tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343      | I had this on tickover. Best solution was to drop the sump plate, remove the pickup and strainer, and clean the strainer using a sharp pick. If the guides have previously gone then there will be bits in the strainer restricting the oil flow. Easy job to do.
|  26th May 2025 11:36pm |
 The other things you may need are the filter housing rubber mounts. They do fail and tear apart leaving the oil filter housing hanging. 2 off part no. LYD000010 https://www.roverparts.com/filters/oil-fil...zNDw8QawqM Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA | ||
|  27th May 2025 3:45am |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | Change your filter for a MANN filter
|  2nd Jun 2025 11:28am |
| Posting Rules
