Home > Maintenance & Mods (L405) > It always self levels to the ground when jacking up.
fisha
How do you stop it ? Seriously ... how?
Over the couple of years I've had with the L405, I've tried various combinations of having the doors and / or tailgate ( upper and lower ) open when jacking up the L405, and it feels like everytime its poos its pants and tries to self-level ... leaving itself squat on the ground on the other 3 corners. Which is a monumental pita sometimes.
So ... what's the trick ? Is there a definitive lockout method ? V8 or else ...
Post #718194 19th May 2025 10:05pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Have you tried pressing and holding the suspension button down to lock, that should bong and that should lock in lowest position? Always works for me.
Post #718197 19th May 2025 11:39pm
Gremlin500
I always jack mine up from access height, and never have had any issues.
It seems a dumb idea I know, but my reasoning is, if the air suspension decides to let go for any reason, you have less chance of getting crushed? Or, is that totally dumbass? Embarassed
I have a 3Te trolley jack with 560mm of lift, so height isn’t a problem.
Surely if the ignition is off, it shouldn’t be able to self-level anyway?
Always use wood blocks/axle stands/wheel wedges under there as well of course, (I don’t mean Fisha/DrF, you guys know your stuff, just any newbies who may be reading this), these are seriously heavy vehicles, and can decide to do their own thing at a moments’ notice, if the vehicle is “live”. V6 Vogue - “Less is More” - less to go wrong!
Post #718199 20th May 2025 12:35am
I've heard various things over the years, hazard lights on, boot open & a door open was the most popular. Others have said just a door open will stop any levelling.
I've never had a problem with just being in park, handbrake on & ignition off.
What are you trying to jack it up with ? I've got a 3T trolley jack & it seems to just lift it up without a problem, albeit it does end up quite high.....
I swap winter & summer wheels, so jack all 4 corners twice a year.
Post #718207 20th May 2025 7:04am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
My Wife's P38 self levels whenever it feels like it, even after hours of being switched off. Not sure if they carried this curious feature on to the 405 but I always lock mine in access and it seems to behave.
On the X350 Jag I have to take a fuse out or it will try to lower no matter what I do and the end result is always, suspension on the bump stops and it's a PITA to get the jack out.
Post #718208 20th May 2025 7:34am
fisha
Jack height / reach isn’t the problem for me. Ideally I would like to be able to park up in off-road height, jack one corner to get the wheel off, and all other corners remain in off-road height.
To me that means I get the best access under the car… and also keeps the car as flat as possible when jacked. But it often then self levels and drops to the bump stops … this make access under harder, and also when it does it it starts pulling and moving on the jack and angling the car which I think is unsafe. V8 or else ...
Post #718210 20th May 2025 9:40am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
The Classic and P38 wake up every few hours and level. I believe the idea is that if there is a slow leak, the car remains level rather than down in one corner.
I don't know if the newer ones do it. They probably do, but are less prone to leaking!
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #718273 20th May 2025 9:36pm
