Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 14 of 14 <123 ... 121314
GraemeS
Australia
Mine takes considerably longer to get up to temperature with EGR mapped-out than before even in the middle of summer here, so in cold climates you might be waiting a long time.
Post #682306 10th Jan 2024 7:54am
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Mine hasn't changed in time to get up to temp and it was -7c here on Tuesday morning... Cam
2011 TDV8 Vogue in Stornoway Grey
Post #682470 11th Jan 2024 10:51pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Old thread ressurection time ,
Those of you that have been running with an egr delete for some time now have they caused any issues ?
Post #718133 17th May 2025 11:40pm
telly-addict
Yes it has; a much cleaner intake and improved mpg and response Thumbs Up Cam
Post #718138 18th May 2025 10:23am
pcourtney
very pleased that I got my EGR programmed out, this was done when it was re-mapped using a mobile technician that I have used before, he trusts Alientech equipment to do this on JLR vehicles and many others
On my TDV8 4.4 he had to remove the ECU ( lifted it out of the battery compartment area ) , easily done and 45 mins later it was taken on test drive and did seem to have a bit more - but hard to quantify to be honest
its now nearly coming up for 5 years, and am still pretty pleased that I got it done, by the way, you don't need to cut out your DPF ( you should not do it anyway re new MOT rules ) BECAUSE the EGR being programmed out ( soft delete ) is all you need Smile
NB you may want to use Launch UK every 10,000 miles to help clean the DPF from time to time
https://www.launchtech.co.uk/technical-flu...MQBfV1XMhw
Post #718254 20th May 2025 6:03pm
Aviator
If the EGR is removed from the equation will the DPF still be functional or useful?
I tried doing things the right way and the EGR temp sensor nut snapped off, so has left me in the situation of an engine out repair or disable the EGR and remove DPF?
Post #718267 20th May 2025 8:42pm
pcourtney
my car has been exceptional - so yes of course it will be OK with EGR programmed out, and leave the DPF in situ please - no need to take the engine out, you don't need the EGR sensor or anything EGR related once it is programmed out !
Yes it will cost you £200 or so to find someone who can program out the EGR from your ECU, but that it a much bettter place to be than pulling an engine !
Post #718269 20th May 2025 9:14pm
Aviator
That was my train of thought.. Disabling the EGR in other previous vehicles has led to only positve effects on the driving and maintenance experience. Not had a DPF fitted to any of my vehicles until now and it clogged up last week and went into limp mode because the EGR temp sensor was faulty. As previously stated I tried to replace it, but was not succesfull as it was truly stuck in the manifold.
I do not feel removing the engine is a sensible option.
Will the DPF not clog up if the EGR is not functioning? it was my understanding that the EGR valve was an integral part of DPF regeneration.
Post #718271 20th May 2025 9:24pm
pcourtney
your understanding is wrong - the EGR comes after the DPF - it is a closed system
hence why I suggested the use of Launch UK earlier in this thread
Post #718274 20th May 2025 9:39pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Mine is booked in early next week for EGR deletion and a gentle remap.
I´ll report back on the results. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #718298 21st May 2025 2:39pm
Aviator
So do you use the DPF gun that they also sell and gain access via one of the pipes?
Post #718312 21st May 2025 8:06pm
pcourtney
No I did not need to use the gun, just poured in the Launch UK bottle with a full tank of diesel, say every 5000 miles, been doing it for over 5 years and all good - easy life Smile
https://www.launchtech.co.uk/technical-flu...f-cleaner/
Post #718358 22nd May 2025 2:18pm
