![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140
Mine hasn't changed in time to get up to temp and it was -7c here on Tuesday morning... Cam
| matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 111
Old thread ressurection time ,
Yes it has; a much cleaner intake and improved mpg and response |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 973
very pleased that I got my EGR programmed out, this was done when it was re-mapped using a mobile technician that I have used before, he trusts Alientech equipment to do this on JLR vehicles and many others
| Aviator Member Since: 11 May 2025 Location: Berkshire Posts: 20
If the EGR is removed from the equation will the DPF still be functional or useful?
my car has been exceptional - so yes of course it will be OK with EGR programmed out, and leave the DPF in situ please - no need to take the engine out, you don't need the EGR sensor or anything EGR related once it is programmed out !
That was my train of thought.. Disabling the EGR in other previous vehicles has led to only positve effects on the driving and maintenance experience. Not had a DPF fitted to any of my vehicles until now and it clogged up last week and went into limp mode because the EGR temp sensor was faulty. As previously stated I tried to replace it, but was not succesfull as it was truly stuck in the manifold.
your understanding is wrong - the EGR comes after the DPF - it is a closed system - it only comes on when you drive slowly, at higher speeds the EGR is closed because the engine is restricted when EGR is in operation ( EGR was an afterthought to reduce emissions cheaply, but without regard to anything else)
| TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 434
Mine is booked in early next week for EGR deletion and a gentle remap.
So do you use the DPF gun that they also sell and gain access via one of the pipes? |
No I did not need to use the gun, just poured in the Launch UK bottle with a full tank of diesel, say every 5000 miles, been doing it for over 5 years and all good - easy life |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 38
I've read this thread all the way through and I'm considering getting a remap and EGR delete on my 2012 4.4 TDV8, but had a couple of questions.
I had the same sensor fault.. I tried to replace it myself but it felt too jammed in and I didn’t want to risk snapping it. Sent it to local garage and they snapped it off unintentionally. Fortunately the threaded part remained in, blocking the hole. My options were engine removal and replacement of sensor or remap and EGR blanking plate. After removing the intake “doughnut” and witnessing the amount of |
I had the EGR deleted and a mild remap done about a month ago, and I'm pleased to report it was well worth it.
