![]() | Home > Technical (L405) > Range sdv8 doesn't go over 2000rpm.and shut down |
Jass786 Member Since: 29 Apr 2025 Location: Birmingham Posts: 22 ![]() ![]() ![]() |
Any help thanks |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 438 ![]() ![]() ![]() |
Turbo boost pressure sensor more or less vertically above it, it's tucked away under the manifold from what I remember. If you can find it, follow the wiring local to that area as there is a connector going to it. It's made of quite brittle plastic and the hose can snap off. Have a look in the end of the hose to see if it snapped. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Hi can't find have you got any pictures thanks
9F479 on the diagram
Does this cause engine to shut down thanks |
It monitors secondary turbo boost pressure so it's definitely not going to run correctly without the sensor connected. Did you find it? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Can't find it
Was that last picture you posted when the engine was out of the car or is it not of your engine?
If the charge air pressure sensor (the one you are looking for) is not connected the engine will not detect secondary boost pressure and the engine will operate in mono turbo mode and set a reduced performance error.
Hi connected the Turbo boost pressure sensor
Any body thanks |
I think it would be useful to all if you gave us a bit of background to the car rather than one liners all the time. Secondary turbo charge air sensor hoses don't just fall off... L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
