Home > Technical (L405) > Range sdv8 doesn't go over 2000rpm.and shut down
Page 1 of 3 123>
Jass786
United Kingdom 2013 Range Rover Vogue SE SDV8 Barolo Black
Hi
Range rover sdv8 4.4 doesn't go over 2000rpm and shut off
I attached video thanks
Thanks https://files.fm/u/23xfuqaavz
Post #717692 10th May 2025 1:58pm
Sorry, can't see anything of note on that video, only shows the dials for a second and camera is moving too fast...
Describe the issue, stationary or moving, dies when it gets to 2000rpm or won't idle...
We need a lot more info to be able to help...
First thing to do is check the voltage on the one, or two, batteries you will have... Pete
-Click here for Thread-
Post #717699 10th May 2025 4:03pm
Jass786
Hi
Idle perfect
When pedal pressed rev go up to 2000rpm and engine die
Thanks
Post #717705 10th May 2025 4:28pm
Next step is likely to see if there are any faults being logged. Do you have a code reader ?
Post #717706 10th May 2025 4:34pm
Jass786
Post #717709 10th May 2025 6:03pm
Now clear them all and see what comes back... Thumbs Up Pete
Post #717713 10th May 2025 7:32pm
Jass786
Post #717724 10th May 2025 9:49pm
Jass786
https://jumpshare.com/s/sCIN6BSF06ppe3c3bvyw
Post #717725 10th May 2025 9:52pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
There's a lot going on there so I'm guessing some kind of bus failure or water in the loom / damaged loom or just control bus gone crazy.
You don't say whether there's a lot of vibration accompanying those revs or not.
If it were mine I'd disconnect the battery for 10 minutes let everything die and then give it another go after hooking it up, clear all of the codes again.
But don't rev it like you do, gradually increase the revs see if it cuts out at a particular engine speed.
If no joy run through every electrical system see what works and what's not working. If it's cutting out at a specific engine speed it could be a clogged filter only allowing trickle of fuel through, stuff like that.
Good luck.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #717726 10th May 2025 10:21pm
Might find some help here...
https://www.fullfatrr.com/forum/search.php...rch_time=0 Pete
Post #717730 11th May 2025 1:12am
Jass786
https://streamable.com/f894tr
Beeping noise
Thanks
Post #717975 15th May 2025 2:35pm
Kot
With all that going on
What is state of battery?
Have you checked earth grounds under each front wheel arches?
That would be my first port of call. 2018 SE SDV8 4.4 Byron Blue
Post #717979 15th May 2025 3:26pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Beeping noise
Thanks
Fault finding with the air intake system removed isn't going to help as straight away your'e going to have correlation errors between the MAF and MAP sensors detecting wildly different values. Speed control would be my first port of call, and yes it earth's under the drivers side wheel arch. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #717985 15th May 2025 5:08pm
Jass786
Hi can't find speed control under driver side arch thanks
Post #718005 15th May 2025 9:23pm
4RRS
The earth point for this and the abs module are connected to an earth stud under the drivers side wheel arch and is a common failure.
To access the stud, remove the front section of the wheel arch splash shield, 2 push in rivets at a vertical position, one at the inner chassis rail, 2 screws on the wheel arch inner edge and 2 screws below front of liner (up through the bumper lower air diffuser). You'll then see the earth stud on the chassis rail next to the accelerometer.
Even if it visually looks good, put a 13mm socket on it and try and loosen it, chances are it will shear off. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718008 15th May 2025 9:31pm
Page 1 of 3 123>
