Home > My Range Rover > ...Long live the King - Rescue mission
krzysmaxi
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Welcome, everyone!
This might turn into a long thread, so buckle up.
The story begins about five years ago when I bought my first Range Rover. Not long after, I picked up a second one — a low-mileage example with just 50k on the clock. I planned to keep it as a long-term family car.
With great enthusiasm, I started working on it myself. But as I dug deeper, I uncovered a series of unpleasant surprises — each one a testament to the gross incompetence of whoever had worked on the car before me.
Despite my determination to set things right, it reached a point where it felt like a never-ending battle. Fix one issue, and three more appear. Too many gremlins.
Recently, I came across another L322 Autobiography. Clean title, solid service history — but a shot engine.
So, with a heavy heart, I made the decision: the engine from my white SE will be donated to the grey Autobiography.
One more twist — the entire swap will be done without a ramp, as I’ve unfortunately lost access to my friend’s garage.
Let the journey begin.
Post #718540 25th May 2025 10:31am
NOTSHARP
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
You may not be, but I am looking forward to following this thread. Thumbs Up
Steve.
Post #718542 25th May 2025 11:11am
krzysmaxi
Phase One: The Donor Strip-Down
The first step was prepping the donor vehicle for the swap.
At first, I considered removing just the engine. But since the donor will eventually be broken for parts anyway, it made more sense to drop the engine and gearbox together.
I started by stripping down the entire front end — bumper, grille, headlights, the lot — to gain access to the radiator pack, wiring looms, and the maze of hoses at the front of the engine. Let me tell you, it's a full-on spider web in there.
Working on a vehicle of this age means one thing: broken clips and fir-trees. No matter how careful you are, they’re brittle and most don’t survive. These will need to be replaced during reassembly in the recipient car.
Despite the complexity, it’s clear the engineers had some foresight. Once you expose it all, the engine and gearbox actually seem designed to come out as a complete unit.
This first stage took a few days — just a couple of hours each evening after work. Thankfully, the weather was on my side.
Post #718576 25th May 2025 8:24pm
krzysmaxi
Phase Two: Drop It Out
Once you’ve wrestled through the mountain of wiring and hoses, and pulled both main looms for the engine and gearbox from the ECUs, it’s time to get underneath the car.
Down there, you’ll find a handful of connectors at the rear of the gearbox and on both front sides — mainly lambda sensors, DPF sensor wiring, and some transfer case controls tucked at the back. Don’t forget the neutral cable pull on the left side of the gearbox — easy to miss, but essential.
Since the engine and gearbox are coming out as one unit, the only driveline connection that needs to be undone is the rear prop shaft at the transfer case.
To access the main bolts holding the engine and gearbox, you’ll need to remove the heat shields first. Only then can you reach everything properly.
Next up: propping the whole assembly. I used a pallet truck, which worked well enough for the job. Once everything was safely supported and secure, I removed the subframe bolts.
Quick confession — I missed a small heat shield above the left anti-roll bar mount and tore it off when lowering. A minor mistake, but a good reminder to double-check those hidden bits.
To fully drop the assembly, the four bolts holding the uprights to the shocks have to come out. Once that’s done, the whole front subframe with the engine and gearbox is free to roll out.
Post #718707 28th May 2025 9:03am
toby1
You are quite mad. Well done, watching with interest! 2012 Vogue TDV8 in Aintree green over sand
Post #718722 28th May 2025 2:54pm
krzysmaxi
Mad... yeah, can't argue Toby1. Wifey keeps saying that each time she passes looking at it...
Phase Three: Strip Down
With the entire lump finally out of the donor, the real teardown could begin.
This stage focused on splitting the engine and gearbox apart. Some components went straight onto the shelf and will be listed for sale, while others are being saved for reuse in the transplant. Organization is everything at this point — especially when you'll be cross-referencing or reinstalling parts later.
It’s a messy, meticulous job. Years of grime have to come off, every connection inspected, and signs of wear noted. But it's also where you really get to understand what you're working with.
Thankfully, despite the donor’s rough history, the engine itself turned out to be in surprisingly good condition — a small but very welcome win in a project full of uncertainties. Knowing this unit since it had only 50k miles on it gives me some peace of mind.
That said, I’m taking no chances. The rear crankshaft seal is being replaced, along with anything else that looked suspect or would be difficult to reach once the engine is back in.
I do wish I had more time to give everything a full cosmetic refresh — new bolts, fresh paint, the works — but for now, practicality wins over perfection.
One small upgrade, though: the subframes are being reconditioned. They’ve been sandblasted, acid cleaned, cold galvanised, and will be finished in Tough-Ox coating. That part’s still in progress — photos to come.
Post #718819 30th May 2025 8:32am
krzysmaxi
Crankshaft seal turned out to be a good call — a small leak was already starting to appear.
Subframe was stripped and sent off for blasting:
The result is looking great.
A critical step here is to treat the surface with rust-inhibiting chemicals immediately after blasting to prevent flash rust.
I’ve looked into most of the well-known rust treatments, and honestly, about 99% of them are based on phosphoric acid, just with varying extra ingredients and acid concentrations.
After the acid treatment, the next step was cold galvanising — basically a high-zinc content spray (fancy name for simple process LOL).
Pro tip: Apply it in thin layers only. Don’t build it up thick, or it’ll cause problems later. This is not designed to be high build primer.
The weather lately has been messing with progress on prepping the donee, so for now it’s a case of fitting in small jobs — like frame work and prep — whenever the weather gives a short window to continue the strip-down.
Post #719270 6th Jun 2025 9:36am
Top job, looking forward to reading the progress
Don't forget the three most important things
Rust proofing
Rust proofing
and
Rust proofing
Thumbs Up Bow down Thumbs Up Pete
Post #719298 6th Jun 2025 12:15pm
dhallworth
That looks a lovely job. Definitely a job worth doing properly. Once done properly you'll get many years of rust free service from that. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #719344 6th Jun 2025 9:49pm
krzysmaxi
Rust proofing
Rust proofing
and
Rust proofing
Thank you Pete.
Yeah… rust.
I really wish the parts could have been either electrolysed or acid dipped, but the local place stopped offering dipping services due to new legislation — which, ironically, never even came into force. That’s made the process both more difficult and a lot more expensive.
So, blasting ended up being the most practical option.
The bare metal was prepped using Eastwood After-Blast, which provides an etching and zinc phosphate coating — supposedly ideal for overcoating. Next came a zinc-rich primer, followed by ToughOx.
I’m genuinely curious to see how ToughOx performs in the long run.
Post #719348 6th Jun 2025 11:22pm
The subframes seem to corrode from the inside out, I'd flood the inside with rust proofer and keep moving it's orientation so every last bit gets some, probably need to tape off a lot of holes etc...
IMHO I don't think you will ever stop the rot but you certainly can delay the process by a large amount... Thumbs Up Pete
Post #719360 7th Jun 2025 9:37am
krzysmaxi
Does anyone near Bishop's Stortford have a crankshaft magnetic ring installation tool which I could borrow for couple of hours?
Tool: 303-1237
Post #719458 9th Jun 2025 9:30am
krzysmaxi
Donee in Preparation
The engine has been removed — transmission left in place. I have to say, removing the engine alone is definitely more time-consuming and awkward due to limited access to the bell housing bolts.
That said, the knocking engine is now out and set aside for the time being. I’m quite interested in finding out the cause of the failure — maybe even rebuilding it down the line. We’ll see…
For now, it’s all about tidying up the engine bay and getting everything prepped for the transplant.
And of course — everyone’s favourite — rust treatment. All the usual suspect areas will be addressed before the new engine goes in.
Not my favourite job by any means… but it had to be done. Polystrip wheel, wire brush, chemical treatment, and even some spot sandblasting — a seriously messy and unpleasant process, but essential to slow the rot...
Post #719586 11th Jun 2025 12:42pm
Good job, yes. much easier to get to everything with the engine out.. are you going to do something with the front subframe, powder coat, galvanise etc..? Pete
Post #719593 11th Jun 2025 1:56pm
krzysmaxi
Yes… you caught me early 😅
I don’t have any better photos just yet — still working on that.
So far, the subframes have been blasted, then cleaned with Eastwood After-Blast, which etches the surface and leaves a zinc phosphate coating. After that, they were etch-primed with a high zinc-content primer — technically considered cold galvanising — and finished with ToughOx by ProXL.
The colour? It's from the Land Rover palette: Tangiers Orange (LRC761) — also known from the G4 Challenge batch.
You can find the blasted pics earlier in the thread.
Here’s how it looked after the After-Blast treatment:
Painted with ToughOx:
Before mounting them back, I’m also planning to treat the most vulnerable and hard-to-reach areas — especially the tight corners and enclosed sections — with a wax- or grease-based corrosion inhibitor. Just an extra layer of protection where paint alone might not be enough.
Post #719598 11th Jun 2025 3:25pm
