![]() | Home > My Range Rover > ...Long live the King - Rescue mission |
| NOTSHARP Member Since: 04 May 2025 Location: Aberdeenshire Posts: 63
You may not be, but I am looking forward to following this thread. |
| krzysmaxi Member Since: 26 Jun 2021 Location: Bishop's Stortford Posts: 29
Phase One: The Donor Strip-Down
Phase Two: Drop It Out
| toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 313
You are quite mad. Well done, watching with interest! 2012 Vogue TDV8 in Aintree green over sand |
Mad... yeah, can't argue Toby1. Wifey keeps saying that each time she passes looking at it...
Crankshaft seal turned out to be a good call — a small leak was already starting to appear.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Top job, looking forward to reading the progress
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
That looks a lovely job. Definitely a job worth doing properly. Once done properly you'll get many years of rust free service from that. |
Thank you Pete. Yeah… rust. I really wish the parts could have been either electrolysed or acid dipped, but the local place stopped offering dipping services due to new legislation — which, ironically, never even came into force. That’s made the process both more difficult and a lot more expensive. So, blasting ended up being the most practical option. The bare metal was prepped using Eastwood After-Blast, which provides an etching and zinc phosphate coating — supposedly ideal for overcoating. Next came a zinc-rich primer, followed by ToughOx. I’m genuinely curious to see how ToughOx performs in the long run. |
The subframes seem to corrode from the inside out, I'd flood the inside with rust proofer and keep moving it's orientation so every last bit gets some, probably need to tape off a lot of holes etc...
Does anyone near Bishop's Stortford have a crankshaft magnetic ring installation tool which I could borrow for couple of hours?
Donee in Preparation
Good job, yes. much easier to get to everything with the engine out.. are you going to do something with the front subframe, powder coat, galvanise etc..? Pete
Yes… you caught me early 😅
| All times are GMT |
