Home > Maintenance & Mods (L405) > L405 Battery Sensitivity, Beware Of Fitting Wrong Battery!
My BMS is faulty Mickey... Back with JLR dealer again this week 😤 tried a download with LR Assist but that didn’t work! So back for the dealer to rectify AGAIN!!!
Post #504212 6th Feb 2019 11:38pm
Mikey
At least you K ow it wasn't your doing Laughing Thumbs Up
Post #504630 9th Feb 2019 6:02pm
The Jury is still out Micky! Once again the main dealer is taking their time Banging Head They've had it a week already Whistle "Mind over matter n all that!" They also have an FBH pump to change and a valve block TSB... So I'm not expecting it back anytime soon Thud
Still, keeps the miles off her! & At least the D4 gets a little more use now Thumbs Up
Post #504661 10th Feb 2019 12:23am
So, car back today with a new FHB pump, suspension knock sorted and the battery management fixed... YAY!!!
Post #505315 16th Feb 2019 1:37am
Mikey
So, when are you swapping the battery back over? Rolling with laughter
Post #505382 16th Feb 2019 5:18pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Registering batteries
Picked up this old thread and wonder if someone can help me.
I have 2 new batteries to fit and realise the batteries need to be registered so what happens and how does the reset tool know which battery has been changed - or in my case, that both batteries are being changed? Is this all done within the BMS? L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #718735 28th May 2025 4:45pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Depends on the reset tool that you use. I have a couple but using the iCarSoft LR v3 it knows there are 2 batteries and so you are able to reset each one individually. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #718739 28th May 2025 5:11pm
Big Vee
United Kingdom 2019 Range Rover Autobiography SDV8 Corris Grey
Quick question in relation to replacing both batteries, do these need to be fully charged or not ? Or Is the car clever enough to know the actual state of charge for each. Cheers B V
Post #724771 18th Sep 2025 10:18pm
I don't know the answer, but I installed both mine as delivered, with no additional charging and it's been fine.
Post #724780 19th Sep 2025 8:14am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
The BMS estimates the state of charge for each. I think that it will improve its estimate over time, as energy flows in to and out of the battery. In my case when I reset the BMS stats the estimated state of charge changed to 90%, though the battery had been charged before installation.
Post #724802 19th Sep 2025 2:14pm
