![]() | Home > Maintenance & Mods (L405) > L405 Battery Sensitivity, Beware Of Fitting Wrong Battery! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
At least you K ow it wasn't your doing |
The Jury is still out Micky! Once again the main dealer is taking their time |
So, car back today with a new FHB pump, suspension knock sorted and the battery management fixed... YAY!!! |
So, when are you swapping the battery back over? |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Picked up this old thread and wonder if someone can help me.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
Depends on the reset tool that you use. I have a couple but using the iCarSoft LR v3 it knows there are 2 batteries and so you are able to reset each one individually. _______________________________________________
Big Vee Member Since: 27 Dec 2023 Location: Lancashire Posts: 22 ![]() ![]() ![]() |
Quick question in relation to replacing both batteries, do these need to be fully charged or not ? Or Is the car clever enough to know the actual state of charge for each. Cheers B V |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I don't know the answer, but I installed both mine as delivered, with no additional charging and it's been fine. |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 155 ![]() ![]() ![]() |
The BMS estimates the state of charge for each. I think that it will improve its estimate over time, as energy flows in to and out of the battery. In my case when I reset the BMS stats the estimated state of charge changed to 90%, though the battery had been charged before installation. |
