![]() | Home > Maintenance & Mods (L405) > 2020 Deployable step obstruction on deployment |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1756 ![]() ![]() ![]() |
Hi Fez, yeah this problem is very common, search “deployable steps” above and read on, & on, & on…
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
anyone know how to disable the steps in a L405? I'm off to the snow and prefer them not to get dunked up.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 348 ![]() ![]() ![]() |
Yep, that's the one. Get in the car and close door so steps retract, then press and hold the button in before switching ignition on, switch ignition on and it should flash a few times to indicate the steps are disabled. Repeat same procedure to re-enable. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
fez Member Since: 24 Jan 2025 Location: UK Posts: 11 ![]() ![]() ![]() |
Quick question does any one have the steps for removing the steps, so I can remove the hinges, want to make sure I only remove what I need in the right way. Looks like I need to remove some of the panels but just want to check before I start just pulling on pieces |
Some one mentioned I should also disconnect the battery for 10 minutes to reset the steps, is that correct?
heretolearn Member Since: 27 Oct 2024 Location: Kuala Lumpur Posts: 44 ![]() ![]() ![]() |
Did you managed to get the steps to work properly? I recently found my aftermarket step module was causing canbus conflict so I proceeded to replace it factory wiring harness and module. Once I coded the ccf via iid tool the steps would deploy and almost immediately retract with obstruction message on screen. Same behaviour on both sides. The steps are only fitted for 2 months so I doubt anything is stuck and has been working perfectly with the aftermarket module. Now I'm thinking if the aftermarket motor and hinges may not be suitable to the factory module. Or if I'm missing something. |
Unfortunately not yet, I changed the motor on the side that was complaining of obstruction and found that some one else had already changed it, missing clips was a give away, with the new motor no change acted just like the previous one.
Some progress on my side. Loosen all the bolts holding the bracket and started jamming the steps before it auto retracts. Did this couple of times and it seems to stay this way. I tried lock/unlock, open and close on multiple times and everything seems ok. I'll need to tighten up the brackets and see if it stays this way. That means the aftermarket motor is reacting well to the module. Its probably the bracket alignment that needed attention. |
It went back to the same behaviour once I bolted everything down. What a let down!! Is there any programming or calibration available to address the side steps or its purely hit and miss with the hall sensors? |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 47 ![]() ![]() |
On my L460, the factory instructions I used for my aliexpress knock offs (which look great by the way), had me put everything on loosely, then attach the side step to the bracket, then fully tighten and torque sequence the bolts holding the brackets in to the body front to back 3x. So it won't bind like yours is.
