![]() | Home > Maintenance & Mods (L405) > L405 Service Interval Indication |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8045 ![]() ![]() ![]() |
I'm not sure if it was ever added as a menu option, but if you buy a code reader that plugs into the ODB port you can see the information that way.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1765 ![]() ![]() ![]() |
Yes, search “dilution” on here & get reading! 198 threads mention this |
detgnome Member Since: 21 May 2025 Location: Kent Posts: 11 ![]() ![]() ![]() |
So with the aid of my new OBD reader I was able to see that there is an implied dilution of over 10%, which answers the original question. Oil change tomorrow and oil reset to follow. |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 577 ![]() ![]() ![]() |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1381 ![]() ![]() |
With great respect.
Equally, the lab could get it wrong, -but not 3 times in a row?
Maybe the V6 doesn't have oil dilution issues as much as V8, never really looked at the architecture between them. Maybe JLR just used the same algorithm for both without studying them?
Lab results and lack of extra volume seem to bear each other out, so that validates it for me.
thrash it ....you know you want to really |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 189 ![]() ![]() ![]() |
Haven't seen a passive regen in 2 years of obsessive monitoring. I occasionally see a downward blip. If it's up around the 70mph and pulling hard up an incline the exhaust temperature will rise to around 380 and grams of soot might drop by about 0.5 for a minute or two but it soon returns to where it was. Maybe a fast run pulling a big trailer would do the trick. |
